| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Please help me. Made a noob mistake and bought this: FS:PASS B1 (CLONED) preamp completed, 2 months used like new
It arrived with 220V transformer. I would like to replace it so I can use it here where I live in the US. The blue wires from the transformer are labeled 18 VAC and connect to "Super regulated power supply ideal for B1 Buffer preamp." I thought I would be able to remove the exisiting and solder in a new one. Any suggestions (about the transformer I mean)? |
#2 |
Yeah, shouldn't be a problem. You just need to replace the transformer with one that has a 120V primary.
The replacement should have a 120V primary, 18V secondary and an adequate power rating. I'd guess that the existing transformer would be rated at around 50VA. It will be written on it, so check. The new one should have a rating greater than or equal to that. Your local electronics store will probably have something that would suit. Otherwise, pick your favorite online retailer. |
#3 |
Thanks very much, appreciate your time. I ordered from Avel Lindberg and Melanie was very nice too, even though I just ordered one transformer.
| Thread Tools | |
| Auxiliary Supplies: Top Switch or small transformer? | EnvisionAudio | Power Supplies | 6 | 19th June 2008 04:17 PM |
| Using 2N3055 and transformer to switch 220volt | jacquesl | Everything Else | 3 | 6th December 2006 04:05 PM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 10:24 AM |
| Outlet to transformer switch for GC... | mcelaj | Chip Amps | 2 | 16th December 2003 11:37 AM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 09:23 PM |
| Page generated in 0.14881110 seconds (66.63% PHP - 33.37% MySQL) with 10 queries |
