Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd June 2009, 09:29 AM   #11
PigletsDad's Avatar
A really good book is "The Art of Electronics" by Horowitz and Hill, which covers everything you ask.
The only thing I would mildly warn against in it is the coverage of digital electronics, which is now fairly old fashioned; a lot of the things they talk about would generally be
more easily solved using a microcontroller and software.
Old 4th June 2009, 09:39 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Professor smith,
The very best thing you could possibly do for yourself right now is to learn how the parts work. Once you learn how things like transistors (BJT, JFET and IGFET), diodes and other basic parts work, you will be able to understand simple circuits and build on that.
But you absolutely must learn how the parts work if you wish to have any hope at all in going further.
One resource that no one has mentioned yet. Buy one of those 250 in 1 learning kits. This will allow you to learn with a manual. There are wires and spring connectors to make fast connections. Believe me when I say that these are a fabulous way to learn. It's hands on, safe and instructed. Couple that with some books later and you are well on your way. After you have learned, you can construct simple circuits with it, or use the parts as you go along.
After that, you can buy some "perf board" and make up your own circuits. If they work out, transfer your design to a proper PCB if you intend to use it. To be honest, I still have some test jigs I use built on perf board. Lazy I guess.
This represents the least expensive and fastest way to learn. I have taught many budding technicians this way - it works.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 4th June 2009, 11:03 PM   #13
IMHO, this should be the last place you try to learn electronics. Not because diy isn't full of wonderful knowledgeable people, but because we're so often concerned about minutia. Though you may pick up some facts, and some misleading myths, your overall viewpoint will be seriously skewed.
There's a lot of electronic info on the 'net, but the reality is that the net stinks when compared to good reference and text books. I second getting a copy of Horowitz and Hill. You should also have a copy of Boylestead's circuit analysis book, Check your local and on-line bookstores. You can often get old electrical engineering textbooks like Timbe and Bush very cheaply. These will teach you basic concepts like conductivity, plus a lot about physical components. The math is usually far clearer than much of the propeller-head junk published today. Get an old copy of Electrical Measurements by Stout or by Harris. If you have some extra cash, get Jim Williams and Bob Pease's books too. There's a wealth of info in any of the ARRL handbooks, though they tend to approach things a bit differently than non-RF people might. Whatever you do, get some basic test equipment and build simple circuits until you can reliably make things that work and understand why, especially if they don't.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 8th June 2009, 09:20 AM   #14
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
There's something to be said for taking a real course, where you're tested on material
This makes sense to me. One of the reasons that electronics is rewarding is that it combines the cerebral and hands-on activity. The best way to learn honds -on stuff is watching some other hands..
The structure is also good as Dangus said- keeps you moving along. Also they tend to have things such as oscilloscopes and such for you to use.
To expect the experts to spend enough time to teach an individual about the subject is unrealiastic and a huge imposition. They have to work too, and to expect them to teach all the basics to someone, one painful step at a time is unreasonable.
Old 8th June 2009, 08:47 PM   #15
I was nearly blinded by an led which exploded when i was using one of those kits as a kid. It shot straight up into the ceiling.
By the way Variac can you open up my thread again at some point?
I have some more questions and now that it's been closed I have been denied any help from members.
Old 8th June 2009, 08:49 PM   #16
i am very impatient though so how long would it take for me to start to understand these things and be on the same footing as people such as Dr. Carlos and Dr. Nelson Pass? Lets keep in mind I am a total beginner.
Old 8th June 2009, 08:59 PM   #17
Netlist is offline Netlist  Belgium
Netlist's Avatar
Lets see, I predict two months, five days, seven hours, fiftheen minutes.
I'm not sure about the seconds though.
/Hugo
Old 8th June 2009, 09:21 PM   #18
anatech's Avatar
Hi Professor smith,
See? I told you this is a good way to learn. Why ever did you stop using the kit?
Get another kit. Better buy it new so you know all the parts are good. If the LED is missing, it's not new!
That's probably why the LED popped. Actually, more like a cute little snap.
Anyone else you want to name as an intellectual target? Mr. Pass has learned for his entire life. He even attended post secondary school for electronics. So, it would seem that if you were bright enough, it would take you about the same amount of time as it did Mr. Pass here.
How long would you expect it should take you to amass the knowledge you figure you need Kenji? Don't forget that we were never interrupted by things like the internet when we studied way back when. We paid our tuition (thousands), bought our books (and read them), did our labs and got marked at exam time. We all studied further at home and often bought what test equipment we could afford. I remember signal transistors cost over $5 each, capacitors were valuable, so we took all the resistors and caps we could find out of discarded TVs and things. That was dedication.
How far are you going to go to learn?
How long will you be in school after you enroll this September?
I'm sure some of us will still be alive by the time you're done learning.
-Chris
Old 8th June 2009, 09:32 PM   #19
John Curl perhaps? They are the 3 main geniuses here.
I have this summer free. So I should be able to learn the basics by then.
Old 8th June 2009, 09:35 PM   #20
MJL21193's Avatar
And DX is one of them?
Sorry, couldn't help it.
Electronics diagnosis and repair learning web-sites? KP11520 Equipment & Tools 20 13th June 2007 04:08 AM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 09:19 AM
Page generated in 0.12591 seconds (82.73% PHP - 17.27% MySQL) with 10 queries
