Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Can I use 4-pin Molex connector as speaker connector?
Old 27th May 2009, 06:53 PM   #1
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Default Can I use 4-pin Molex connector as speaker connector?
I was thinking about using those 4-pin Molex connectors like you see on computer hard drives as a speaker connector.
Is this possible? I won't be running very high power, it's a TA2020 t-amp that will be putting around 20W rms into a 4ohm speaker, I guess the current won't be more than 1 or 2 amps...
Any disadvantages or reasons not to do this?
I was going to have the amp in my car, and I want it to be easily removable, and I thought using molex connectors would be ideal for quick and easy connection.
I guess speakon is also an option but it seems overkill for such low powered speakers...
Old 27th May 2009, 07:13 PM   #2
riktw is offline riktw  Netherlands
yes you can, molex connectors can handle lots of power.
Old 27th May 2009, 10:35 PM   #3
MikeHunt79's Avatar
Excellent, thanks for the info.
Old 3rd June 2009, 09:02 AM   #4
dangus is offline dangus  Canada
My concern would be that it's bad practice to use what is nearly always a DC power connector for anything else.
Cutting down an AT style power supply connector would be a safer way to go. Insertion force is less, too, which means less risk of damaging pads if you've built a single-sided board.
Old 3rd June 2009, 07:40 PM   #5
Steerpike is offline Steerpike
Steerpike's Avatar
You can 'customise' molex plugs & sockets to make them unique and impossible to cross-plug, by mixing and varying the number and sequence of male/female pins in a male/female shell.
This applies to the inline and panel mount types; I'm not sure if the PCB variants come with loose pins.
Steerpike's Toybox
Old 3rd June 2009, 08:21 PM   #6
thoriated is offline thoriated  United States
I hear you. One of my earliest self taught lessons in electronics came when I was 12 years old and had the bright idea of using a 1/4" phone plug as a power connector for a tape recorder I was modifying. One detail I overlooked was that the hot tip and sleeve would be momentarily shorted while inserting into the jack. The result was a charred plug and jack, hole burned in the carpet and upset parents.
Can I use 4-pin Molex connector as speaker connector?Hide this!Advertise here!
How to connect molex/ multipin connector lgreen Construction Tips 10 25th August 2009 01:26 AM
PPI Speaker Connector Rickdogg Car Audio 2 10th September 2006 09:15 PM
ATX connector MaXiZ Everything Else 15 3rd January 2006 09:02 AM
Finished my DIY Copper foil speaker cable, what connector to use? Guijs Everything Else 4 19th October 2005 11:31 PM
2 13" LCD monitors - Molex power connector. zmoz Swap Meet 2 24th April 2003 01:15 AM
Copyright ©1999-2017 diyAudio
