| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
guys would probably know that I just got this used SME 3012.
now I found out that 1 of the 4 internal pins of tonarm that contact with the 4 pins of the cartridge is apparently pushed a little further deep inside the arm (as compared to the other 3 pins) and this leads to a loss of volume of the left output/speaker. is there any simple way to fix this by myself? (someway to pull it out) any helps or instructions would be much appreciated. Karry |
#2 |
is this a detachable headshell version?
regards Andrew T. |
#3 |
The 3012 comes only with a detachable shell. One of the spring-loaded pins inside the armtube is stuck, which is quite common. Usually easy to pull out and some lubrication will also help. It is a standard replacement part which appears often on Ebay and is probably available from SME.
#4 |
thx for your reply. I got the same advise from else and now just have the sme work fine again. the best tonarm ever.
best regards, K |
| Thorens TD 125 with SME 3012 | Karrry | Everything Else | 14 | 30th April 2009 02:58 PM |
| SME model 3012 Series 2 | BrianDavid | Vendor's Bazaar | 6 | 20th August 2008 08:53 AM |
| SME 3012 series 2 value? | dhaen | Analogue Source | 28 | 6th November 2007 06:48 PM |
| Sme 3012/2 | Thago | Analogue Source | 0 | 3rd November 2007 10:28 PM |
| Page generated in 0.06216 seconds (73.62% PHP - 26.38% MySQL) with 10 queries |
