| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
Looks like a nice amp! The coupling cap isolates two stages in an amplifier to prevent the passage of DC. (audio signals are AC)
They are usually small, like the two I suspect are bad in the Sherwood amp. When they go bad without leaking and fail intermittently, that's when I get a little mad. Finding the bad one in a big multichannel amp can be a nightmare. |
#12 |
To find a bad coupling capacitor,
Just connect a good one across it. OR use crystal earphone to hear the audio. Gajanan Phadte |
#13 |
I finally got the chance to have a look at the Amp tonight with some interesting findings....
After blowing all the dust out of it and getting settled down I figured out the best way to remove the board from the chassis, this was thankfully an easier task that I had first imagined. With the board out I flipped it over to see if there were any of the cold solder joints that hardwareguy had cautioned about. I must say I was expecting the worse but I was pleasantly surprised, I'm no soldering expert but everything looked quite nicely done: Click the above pic for a super res pic The Eagle-eyed may have already noticed something amiss down at the bottom right. On closer inspection; On closer closer inspection; I flipped the board over to see what awaited me on the other side; There we have it, R902SL seems to be the culprit, this would make sense as its marked as 'SL' which I would speculate to be 'Surround Left', the faulty channel. The others around it being labeled as; 'SR' (Surround Right) 'FL' (Front Left) 'FR' (Front Right) 'FC' (Front Centre) Which seems to support the labeling abbreviations. I also got another picture of the mucky capacitor that was the original suspect; ![]() I'll be replacing this and its suspected leaky partner in crime to be safe. After this dissection I would propose that at some point the Amp was pushed too hard, possibly with some lower impedance speakers (the Amps rated for 8 Ohms), which resulted in the resistors untimely demise, would this be along the right lines for a cause of death? My biggest question is can the burnt track be repaired? I've never undertaken a retrack (is that a valid word?) before so any pointers would be great. It didn't occur to me to check the resistace of the dead res in comparison to its counterparts so I will do that first thing tomorrow. Other questions are; What are the orange lozenge shaped components, I would guess at capacitors due to the 'C' infront of their assignments. Would any of these need replacing? Cheers
#14 |
Most likely the resistor just ran warm from day one and the solder joint there was less than perfect. The thermal cycles tend to make less than perfect joints go bad. (even good joints don't like wild temp swings)
It looks like the joint has been subject to arcing. To fix it, use solder wick to remove all the old solder then thoroughly clean the joint with alcohol before resoldering the joint. You may want to replace the resistor if you find it is difficult to solder to. Those orange caps are probably good. As they are not electrolytic, they are not subject to leakage. They can last more than 50 years under the right conditions.... I have some in some old tube gear and they are still in spec. |
#15 |
Ah cool so I may be able to re-use the resistor too? I'll get right on that
#16 |
Reuse the resistor if the body is not charred or cracked and it measures within the specified value.
It looks like it may be just a joint gone bad, in these cases usually only the lead gets oxidized. A bit of sand paper can renew the surface of the lead so it can be retinned. |
#17 |
Unfortunately the resistor was showing KOhms when its counterparts were showing 10 Ohms so I've got replacements on the way.
The only thing now is the track, despite a wipe over there is still some blackening, I had thought of soldering on a length of copper cable between the leg of the resistor and the next component, would this be suitable or is there a different method I should use to renovate the track? |
| Repairing MIT IC´s question | jev | Everything Else | 3 | 26th June 2008 07:23 AM |
| Help repairing a CS-400 | glaforce | Solid State | 2 | 17th February 2008 08:55 PM |
| repairing a/d/s/ 640 amp | Ocelaris | Car Audio | 2 | 16th February 2006 02:35 AM |
| Repairing VTL TL2.5 | effindi | Tubes / Valves | 4 | 30th November 2004 06:57 AM |
| Repairing an old Mac Amp | diyman | Solid State | 4 | 5th December 2001 09:37 AM |
