Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th April 2009, 06:31 AM   #1
Question Electronics Theory question...
Alright Folks,
I recently picked up "The Art of Electronics" by Horowitz and Hill and I am currently stumped on a particular exercise. I've tried to figure this out for two days now and I have no clue as to what I am supposed to do. My only complaint about this book is that there doesn't seem to be an answer key for the exercises that they have in the book.
Exercise 1.5 found on page 7.
Show that it is not possible to exceed the power rating of a 1/4 watt resistor of resistance greater than 1k, no matter how you connect it, in a circuit operating from a 15 volt battery.
I'm trying to teach my self about electronics and I am a complete noob when it comes to this stuff. I have a degree in English, which I feel is about as far from this type of subject matter as can be.
I was able to figure out the power dissipated in an earlier question but this one completely bamboozles me. Everything I have read up until this point in the text describes resistors as "5k" or "10k" resistor and I really don't understand where the wattage came into play.
Thanks in advance for your help and I apologize if this is an off the wall question to be asking here.
-Pete
"The device uses light tubes to transfer light at the speed of light in order to avoid clipping, pure genius!"
Old 15th April 2009, 07:00 AM   #2
dangus is offline dangus  Canada
You need to remember P=V*I, and I=V/R
So, that gets you P=V*V/R
If V is 15 volts, R is 1k (1000 ohms), then it is:
P = 15 * 15 /1000 = 225/1000 = 0.225 Watts which is less than 1/4 watt.
Maybe you should get a book that covers basic electrical concepts like Ohm's Law in greater depth first.
Old 15th April 2009, 10:39 AM   #3
The 15volt battery can also be used to make a DC to DC converter. If the output voltage is increased, and THE resistor is connected in the output ckt...
This statement is not always true.
Gajanan Phadte
Old 15th April 2009, 11:45 AM   #4
HK26147 is offline HK26147  United States
Here's a calculator:
http://www.doctronics.co.uk/downoeq.htm
from
http://baec.tripod.com/
Print this and keep handy:
http://101science.com/Radio.htm
Syd
Old 15th April 2009, 11:54 AM   #5
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Pete,
The simple way I remember Ohm's law, which will get you the info you need in this case is using these towo diagrams:
. E .
I | R
. P .
I | E
E= voltage, I= current (amps), R= resistance (ohms), P=power (watts)
Between those two diagrams, I can usually come up with whatever measurement I'm looking for. Hope this helps and best wishes in your endeavor.
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, DIY Krystals
Old 15th April 2009, 02:03 PM   #6
Thanks everybody for your help. I understand now how to solve the problem.
I also have another book coming in the mail, which is about basic electricity concepts so I might start with that one and then return to "The Art of Electronics." Thanks again for your time.
-Pete
Question on the theory/practice of 2/3/4...-way speakers JCDenton Multi-Way 3 6th June 2006 06:13 AM
Max SPL theory Question DougL Multi-Way 13 18th March 2005 01:57 AM
question of theory cominup Multi-Way 3 7th May 2004 04:28 AM
Question on L-pad theory/formula leadbelly Multi-Way 8 19th January 2004 05:39 PM
Basic loudspeaker theory question Andrej Multi-Way 6 28th April 2002 06:53 AM
Page generated in 0.09281 seconds (86.72% PHP - 13.28% MySQL) with 10 queries
