| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 | |||
I believe, as a general rule, coax is properly applied when dealing with very high frequencies, waaaay beyond that of audio. In that application, POWER transfer is very important, and the line impedance must be matched with identical source and terminating resistors. You must keep this separate from audio applications, which is a plain old misapplication regardless of the cable construction. Jordan: sorry if this was an unwelcome divergence from your original question. While shielding provides many benefits, if the cat5 is existing, I am sure you could use it with fairly good results. Stick to the twisted pairs, of course; calee4nyaboy is right on the money with his advice. |
#12 | |
You never explained why your goal is to minimize power loss at line levels. This is the heart of our disagreement. You say to preserve the signal but we are talking about driving a 60-100 ft of small gauge wires with no shields. This is essentially the problem of telephony and it's a hard learned path that is well worn. Since we both agree most op-amps do not like driving reactive loads. We have to add some small series output resistance, so it's not really an ideal voltage source. Now then it's not breaking the rules to simply double your 10-20 ohms to get in the neighborhood of Zo. Using 50-100 ohms or so to buffer the output of any op-amp that goes off the PCB is generally good practice anyway. (look at Linkwitz circuit designs) Notice also it's not a big deal of adjusting the op-amp gains at either end slightly higher to make up for any losses in the transmission line. Some really good op-amps like a little extra gain anyway . Now at the receiving end as you lower the impedance of the termination does three things in order of concern here 1) extends to the cutoff frequency of the Cat-5 cable 2) lowers the input noise source at the receiving amp. 3) swamps out signal reflections that will degrade the signal quality. Another concern not even hinted at in this thread is channel cross talk. Just saying it's rather dogmatic to simply preach "use zero ohm sources and high impedance terminations".
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#13 |
There is nothing dogmatic about speaking the simple truth in an attempt to dispel incorrect information. This will be my last post in this thread, and you friend have much to learn:
http://www.sound.westhost.com/cable-z.htm Suffice it to say, after being enlightened by your posts, I will now buy a bunch of 4 ohm resistors. I will then proceed to install said resistor right at the output of my amplifier, in order to properly drive my speaker cable "transmission line". I will gain tremendous benefits of 1) extended frequency response 2) lower noise 3) no more signal reflections |
#14 |
We are talking about long wire runs at line level right! Not for speaker cables (power electronics).
Since this was your last post I guess you won't/can't explain your rule. definition of dogma. 1 a: something held as an established opinion ; especially : a definite authoritative tenet b: a code of such tenets <pedagogical dogma> c: a point of view or tenet put forth as authoritative without adequate grounds
#15 |
We're using CAT5 here at work to distribute audio, and I have a friend who is doing the same thing at home (at my home I'm using individually shielded twisted pairs). It works very well, although we haven't done any measurements.
I'm not sure whether you want to run the sense lines down the cable - it seems to me you could get problems with the sense lines picking up interference. I'd suggest allowing for both local and remote sense and try both. As to the source/receiver impedance issue: I don't see how lowering the receiver impedance would extend the cable's frequency response, and that I very much doubt reflections are an issue at these frequencies. I'm using the TI drivers and receivers and they don't mention anything about matching impedance. See Fig. 2 in http://focus.ti.com/lit/ds/symlink/drv134.pdf |
#16 | |
U can use good general purpose audio op-amps to do something similar but the terminating imp. (lower is better) will be related to the max load and THD of the devices you pick. edit> most likely on the order 1-2K ohms or so. Reflections are an audio problem as in telephones but not severe for short runs like this. that's why it was listed last or #3.
| Convert Line Level to Electric Guitar Level | miallen | Solid State | 4 | 16th May 2010 01:22 PM |
| CAT5e Cable fun! Line level. | Pano | Everything Else | 3 | 25th March 2008 08:32 AM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 04:13 PM |
| Page generated in 0.10570 seconds (82.06% PHP - 17.94% MySQL) with 10 queries |
