Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th March 2009, 09:27 AM   #1
Default 5.1 connector standard?
Hello there
I've searched the net for days now to find the standard for the 3.5mm TRS jackconnectors for 5.1 surround sound.
TRS 1 is front
TRS 2 is rear
TRS 3 is sub/center
Nothing new there.
But how are they connected?
I assume that Sleeve is GND as usual on all 3, but how about Tip and Ring. How are they assigned????
Hoffmeyer ;0)
Old 27th March 2009, 10:10 AM   #2
domtw is offline domtw  France
domtw's Avatar
Hello,
For stereo jacks, I know the ring is for the right channel, the tip for the left one and the sleeve is for ground.
I guess that it will be the same for the surround channels.
I don't know for the center/sub connector...
Old 27th March 2009, 10:24 AM   #3
domtw's Avatar
I found this:
It is for 7.1 channel
Where:
1. Line Out 1 jack
2. Line Out 2 jack
3. Line Out 3 jack
4. Front Left
5. Front Right
6. Ground
7. Rear Left
8. Rear Right
9. Ground
10. Side Right
11. Center
12. Subwoofer
13. Ground
14. Side Left
I would assume that for 5.1 system
9 and 10 are merging into ground
Same for 13 and 14
Old 27th March 2009, 10:48 AM   #4
Originally posted by domtw
Hello,
You assume wrong. The jacks have 3 rings and the ground it is NOT the last sleeve/ring. Cables are identical with the ones for analog video out in camcorders. For example in Creative cards looks like this:
Line Out 1 it is stereo.
Line Out 2 is configured as: Rear Left, Rear Right, and Side Right
Line Out 3 is configured as: Front Center, Subwoofer, and Side Left
Old 27th March 2009, 11:05 AM   #5
Hi domtw
Thank You very much.
I assumed, like You wrote, that the ring would be right, (and not wrong)
Then it just the question with sub/center assignment.
Hoffmeyer ;0)
Old 27th March 2009, 11:22 AM   #6
Hi SoNic_real_one
Isn't that a 7.1 system?
If I'm not mistaken, then what domtw referes to is the 5.1 pin configuration.
Hoffmeyer ;0)
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
Standard SR-157SW Limhes Solid State 24 15th March 2009 11:09 PM
Non-standard rackmount Nixie Parts 5 13th October 2006 01:29 AM
pre standard preamp PMA Solid State 9 10th December 2003 07:19 AM
Page generated in 0.07558 seconds (78.12% PHP - 21.88% MySQL) with 10 queries
