Use of transistor for switching 120AC
Hoping someone could give me hand with this concept.
I need to switch AC to a load based upon a small voltage input of variable amplitude. My idea was to use a FET, with the input at the gate, load(consider it a lightbulb) between 120AC and the drain, and the source straight to ground/ the dead half of a household AC plug. I'm concerned about transistor selection, and the potential for reverse biasing on the negative swing of the 120AC. Any input is appreciated. |
Why not use a triac - its what they're for
Thanks! Wasn't aware of this component. Looks perfect. |
Hmmmm.......
Regarding the mains voltage supply. If you do not know what you are doing leave the mains alone before you kill yourself or someone else. :)/sreten. |
Sreten,
I appreciate your concern, I have a good background in electronics, my coursework is just lacking in 120AC coverage. I have looked at datasheets on the triacs since, and it looks like it will work very well. |
There is a good reason mains circuitry is not usually covered. Proper insulation practise must be followed and you'll need something like an optical-isolator for the control input. :)/sreten. |
If you want an incandescent light to flicker to the music, look for "color organ" schematics. Old electronics hobby magazines, or books with titles like 1001 electronic projects in the library may have circuits.
| All times are GMT. The time now is 01:39 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
