Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Big can caps brands?
Old 21st March 2009, 03:41 PM   #1
HaLo6 is offline HaLo6  United States
HaLo6's Avatar
Default Big can caps brands?
I know this may bring up a lot of subjective opinions but here it goes... What are some good makers of big size caps >40KuF size. I have seen quite afew people like Rifa, any other brands? What is a good ESR rating for those larger caps? what qualities shoud I be looking for, (I will be using them in a PS for a LM3886 chip amp build, the BPA300)
Old 21st March 2009, 09:44 PM   #2
Geek is offline Geek
Geek's Avatar
Cornell Dubilier Electronics makes them for reasonable.
Out of curiosity, why do you need one that big for a 3886? It can't souce the current pulse (and survive) 40,000uF can store and the superior PSRR makes it not neccessary for filtering
Cheers!
Old 22nd March 2009, 02:19 PM   #3
HaLo6's Avatar
Its 3 3886's and the only other build I have to reference off of used 47000uF, (I am new at DIY electronics, so at this point I am more of a cloner rather than a designer )
Old 22nd March 2009, 07:14 PM   #4
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
If you are talking about the BPA300, i have had great results using a pair of rifa 47,000uf caps. Rerember in the original design a single 47,000uf is used per rail, to power 6 x 3886.
Old 22nd March 2009, 08:05 PM   #5
LineSource is offline LineSource  United States
LineSource's Avatar
For the best reliability I purchase 105C temperature rated capacitors instead of the normal 85C, and look for a voltage rating that is over 2x higher than the power supply. Some vendor catalogs spec MTTF and there is a surprising large variation. You should also check the date codes.
Panasonic and Nichicon have good specs.
Old 25th March 2009, 07:32 AM   #6
chris661 is offline chris661  United Kingdom
chris661's Avatar
You can get 1F capacitors from maplin
£30 each, and they have their own digital readouts (not sure what it's for though...)
Don't know who makes them, and I would check... if the maplin sites comes back.
My work: www.grimshawaudio.com
Old 25th March 2009, 08:09 AM   #7
rhysh's Avatar
Those are 13V capacitors for car audio
Big can caps brands?Hide this!Advertise here!
Recommended brands for tube HT psu caps studiochap Power Supplies 8 20th August 2009 06:42 PM
all you wanted to know about brands of caps -and were afraid to ask- federico moreno Parts 4 30th March 2006 08:48 PM
should there be less brands in audio? paba Everything Else 15 26th July 2005 03:25 PM
Different brands:Is there any difference? specter73 Tubes / Valves 8 10th June 2005 05:59 AM
Speaker Brands guitargully Multi-Way 5 16th December 2003 08:56 PM
Copyright ©1999-2017 diyAudio
