| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi all i am trying to repair this old yamaha amp i have put these 2 black new capacitors in now i seem to have this fuse blowing on the board just above them (see photo) is there any way to tell if i have installed them with the polaritys wrong i was sure they went back the same though..
#2 |
This circled in red was getting very hot..
#3 |
The stripe on the capacitor is negative. That will usually be marked on the circuit board somewhere as well. Other than that, it's pretty hard to tell from a photo.
If the caps are in backwards, I'd expect them to release their smoke (rapidly). That white thing looks like an auxiliary power bridge rectifier, which would probably normally get a little warm, but if it's dangerously hot, then there's probably some circuit problem. ..Todd |
#4 |
Hi yes it did get very hot i de soldered 2 of the output transistors(C789) last night and 2 of 4 are dead ,, possibly shorted on the heatsink as the little plastic bush/washer things all broke up when i screwed them back in for the first time ,,
#5 | |
Dual metal plate emitter resistors by Fukushima Futaba (with three legs each).
Looks like Sponge Bob has killed another thread. |
| Am I using Unibox correctly? | zimjj | Multi-Way | 0 | 8th February 2009 12:26 AM |
| Just installed VAM1202..... | martipie | Digital Source | 2 | 29th April 2006 12:01 AM |
| Am I using UniBox correctly? | needtubes | Subwoofers | 3 | 12th June 2005 03:02 AM |
| Just installed EV in my OB's | hurdy_gurdyman | Multi-Way | 2 | 1st June 2003 05:46 AM |
| Page generated in 1.17420 seconds (6.34% PHP - 93.66% MySQL) with 11 queries |
