Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 8th March 2009, 08:44 AM   #21
revans is offline revans  New Zealand
Ok so I got the values from WinISD. Vb was 4.2 litres (but I put in 4.16875 litres as that's the volume of the enclosure I've already built). Fb was 81.94Hz.
I chucked those values into the Vented Box section of Unibox (which, surprise surprise cleared up my port length). I guessed by Pin you meant Nominal Power as it was the only variable watts related thing I could find. I set Nominal Power to 5W and began to move it up while checking the cone excursion graph.
Despite your words about 'slowly', it ended up going in big jumps as the peak only ended up touching the xmax line at 155W (is this okay?). In any case, the bottom of the graph is apparently 82.3Hz - which seems right - does this mean 82.3Hz is the lowest frequency I should place a filter at?
Old 8th March 2009, 01:11 PM   #22
infinia is offline infinia  United States
infinia's Avatar
The graph looks good, but the power s/b around 15W not 150W.
Check Rs value in external components area. s/b inductor Rdc value in fraction of ohms
Anyway. looking at the graph the high pass filter (HPF) corner frequency should be placed somewhere around 70 Hz.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 8th March 2009, 01:30 PM   #23
not much bass from this vented box driver!
regards Andrew T.
Old 8th March 2009, 01:40 PM   #24
infinia's Avatar
That's why this isn't in the subwoofer forum me thinks. Not too much danger of air turb for a 4" driver.
Old 8th March 2009, 01:45 PM   #25
I'm not referring to sub-audio frequencies.
Simply bass frequencies.
regards Andrew T.
Old 8th March 2009, 01:48 PM   #26
infinia's Avatar
Originally posted by infinia
for a 4" driver.
Hi Andrew
It's fs ~70ish Hz
I think a 5 - 6.5 incher would dig alot deeper for not too much bigger size.
Old 8th March 2009, 07:36 PM   #27
Well Rs was 0.2ohms, so I'm not sure what's going on there - but anyway, I guess I'll put in the filter at ~70Hz.
Ah well, now to find out how to do a high pass filter.
Thanks to everyone who replied for your help , espc. Infinia and Andrew
Bass Reflex port for Usher 701 kit nippontiger Multi-Way 7 16th September 2008 04:11 PM
Bass reflex port question Javachip Multi-Way 12 11th April 2006 01:11 PM
Tuning bass reflex port beamnet Multi-Way 0 28th September 2005 02:03 PM
Q-factor of bass reflex port SSassen Multi-Way 6 26th March 2005 09:26 PM
what the max Air velocity of bass reflex port? Audist Multi-Way 4 7th February 2005 09:43 PM
Page generated in 0.11269 seconds (75.80% PHP - 24.20% MySQL) with 11 queries
