| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 | |
Yes, but flares always look cool. Tip- Look at using Unibox program instead of WinISD to model them as well/
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#12 |
Hey thanks for that suggestion infinia. I went and played around with Unibox and it seems a fair bit more in depth than WinISD.
I chucked in all the correct values and got this port speed graph which I've attached (although it wouldn't let me change the port length to the 9.2cm that I'm using). It seems that air speed only exceeds bad levels at about 72Hz and below. Is this a problem? Would I perhaps want to put in a filter to block anything below 70Hz? |
#13 |
What about flaring the internal end of the port? That would be better than no flare at all, correct?
#14 | ||
HP filter would be advised if you plan on pushing SPL's and keeping lower distortion and/or even prevent damage. Look at a sealed box for a 4" if using a subwoofer. Quote:
Yes Unibox lets you model that as well. Also check the box (button) for the port secondary resonance to see.
#15 |
OK thanks for that infinia. I checked port resonance btw, though I'm not sure what difference it made to the graphs.
Anyway though, just to summarise... will the speakers be fine with regard to port noise if I: 1) put in a high-pass filter around 70Hz; 2) flare the internal end of the port; 3) leave the other visible end of the port at a 90 degree exit? |
#16 | |
I don't think you will have any problem with air turbulance.
#17 |
Wow... I looked at the "Cone Excursion vs. Frequency at 25W" [it's attached] and it seems a bit crazy. I'm guessing that according to that graph I should cut it off at about 175Hz... isn't that a little high? The Tang Bands should be able to handle at least down to 100Hz if not 80Hz, so what's up with that?
#18 |
Your tunings way way off. Go back to WinISD and start with the nominal box Vb and Fb, then plug those back in Unibox these will be the lowest tuning you should use.
Now adjust Pin so the top of the graph peak just kisses the Xmax limit line. Looking the lowest point of the graph dip= fb and the area below it is were the port "unloads" the driver. Below that the graph will cross Xmax steeply.
#19 |
Thanks infinia. Just giving your directions a read-over I have no idea what you're talking about, but I'll have a look around WinISD and Unibox and see how I go and get back to you.
#20 |
The first sentence is plain. Take what WinISD gives you and plug those numbers back in Unibox.
Second sentence say's start with 5W of power and move it up slowly untill the peak hits the line. Now look at the graph and reread what I wrote,
| Bass Reflex port for Usher 701 kit | nippontiger | Multi-Way | 7 | 16th September 2008 04:11 PM |
| Bass reflex port question | Javachip | Multi-Way | 12 | 11th April 2006 01:11 PM |
| Tuning bass reflex port | beamnet | Multi-Way | 0 | 28th September 2005 02:03 PM |
| Q-factor of bass reflex port | SSassen | Multi-Way | 6 | 26th March 2005 09:26 PM |
| what the max Air velocity of bass reflex port? | Audist | Multi-Way | 4 | 7th February 2005 09:43 PM |
| Page generated in 0.11564 seconds (76.60% PHP - 23.40% MySQL) with 11 queries |
