| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Here are the specs
Mastech Multimeter Lux Humidity Sound Level dB Meter DCV: 400m/4/40/400/1000V, +/- 0.7% ACV: 400m/4/40/400 +/- 0.8% 750V, +/- 1.0% DCA: 400µ/4m/40m/400m +/- 1.2% 4/10A, +/- 2.0% ACA: 400µ/4m/40m/400m +/- 1.5 % 4/10A, +/- 3.0% Resistance: 400/4K/40K/400K/4M +/- 1.2% 40M, +/- 2.0% Capacitance: 40n/400n/4m/40m/100mF ±3.0% Frequency: 10/100/1K/10K/100KHz/200KHz ± 2.0%, >200KHz,reference only Temperature: -20 - 1000 degrees C (0–1,800 degrees F ) +/- 3.0% (C/F selectable) RH: 20–95%, +/- 5.0% Lux: 4,000/40,000 Lux, +/- 5.0% Sount dB: 40 – 100dB, +/- 3.5% @ 94dB Diode test Continuity tester: Buzzer if resistance is less than 40 ohms |
#2 |
You forgot to mention the price.
Steve/bluewizard |
#3 |
79.95 at multimeter depot these are new and just came out and the winner is Me! I bought 1
I found it on ebay but you can still get it at multimeter depot on the internet |
#4 |
for a multi-purpose meter it specs very well.
I am so glad the designer saw fit to omit transistor hFE. Forcing one to use a proper test.
regards Andrew T. |
#5 |
#6 |
http://www.amazon.com/Mastech-multim.../dp/B00064OZ1K
http://www.amazon.com/Mastech-Auto-R...68WR597Y0ANHZS
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#7 |
#8 |
also very similar or exactly the same
http://www.protektest.com/Prodinfo.asp?prodid=6300 Mouser.com carries it MSRP $69 USD ie can be had for less Harbor freight "had" a rebadged one a while back for around $39.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#9 |
I'm curious how sound level works?
Does it have a built-in microphone? Do you add your own external mic? I also notice that the sound level frequency response is only 100hz to 8khz. That might be good for general sound levels, but not for detailed testing. Is that limited by the internal mic and can it be improved by adding an extremal mic? Still, it's a sweet meter for a very modest price. Steve/bluewizard |
#10 |
There is a microphone, Light meter, temptature/ humidity I will bet some one around here will figure a way to tweek it to take a microphone sooner or later. That also bring up an interesting subject who can tell us how to make a califrated spl measuring microphone up 40khz that will work with it
| Versatile Transformer Selection | SoliS | Chip Amps | 11 | 4th August 2009 05:57 PM |
| Ugly, but versatile, new amp | tubelab.com | Tubes / Valves | 24 | 5th October 2006 01:01 PM |
| Anybody want a job? Mine?? | Jack Crow | Everything Else | 0 | 5th April 2006 12:01 PM |
| Does no one have any car audio? - here's mine | maxw | Car Audio | 23 | 13th November 2004 08:02 AM |
| Page generated in 0.09705 seconds (88.56% PHP - 11.44% MySQL) with 11 queries |
