diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   can i replace mosfet with other N-mos (http://www.diyaudio.com/forums/everything-else/138840-can-i-replace-mosfet-other-n-mos.html)
Ground Zero 18th February 2009 01:19 PM
Hello :)
I have a little problem, with a power supply from a computer.
I have I have a broken transistor N-channel mos-fet
the part number is fqpf5n50c
but i have'nt this part :xeye:
Can you tell me please if i can replace it with this N-channel mos-fet part number:IRFBC40
or STP3NC60FP,
the datascheets are:
http://www.alldatasheet.com/datashee...FQPF5N50C.html
http://www.alldatasheet.com/datashee...S/IRFBC40.html
http://www.alldatasheet.com/datashee...TP3NC60FP.html
thanks a lot for your help
AndrewT 18th February 2009 01:30 PM
Why did it break?
Was it below spec?
Or was it driven beyond spec?
Maybe you need to consider how to make it reliable before deciding on the specification of the replacement.
Ground Zero 18th February 2009 01:37 PM
Thanks AndrewT ;)
I don't know why it was broken because I recovered the power supply.
But i think that's the dust in the power supply blow the n-mos :xeye:
so do you know "with the datasheet " if it was possible to replace the original N-mos fqpf5n50c with one of theses parts IRFBC40 or STP3NC60FP
thanks a lot :)
Copyright 1999-2017 diyAudio
