Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th February 2009, 04:04 PM   #1
Default what is the advantage of twisting and braiding cables?
why?Can anynone explain to me?
Old 17th February 2009, 04:23 PM   #2
DRC is offline DRC  United Kingdom
DRC's Avatar
twisted pairs are often used to carry differential signals. in this case, any stray varying magnetic fields will tend to induce a current equally in both conductors. This equal current will then be rejected at the receiving end - provided the CMRR (common mode rejection ratio) is sufficiently high. The twist is there to help ensure each wire gets the same amount of magnetic flux ...
d
Old 17th February 2009, 05:09 PM   #3
there ara two kind of wires,which is more fit for Braiding Cables ?
1,ten thin copper wires composed one strand
2,one single copper wires
the diameter is same.
I mean the speaker wires!
Old 18th February 2009, 08:47 PM   #4
bear's Avatar
flexible is easier mechanically.
I'd be most concerned with the electrical properties for use either in interconnects or speaker cables...
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 18th December 2009, 08:20 PM   #5
Blacksheepkable's Avatar
Default Braiding
Check out "the naked truth about speaker-cables". Google it and it will come up.
Multi-strand wire is much easier to braid with especially when braiding more than 4 wires. You can braid solid core, but the fewer number of wires, the better. We braid 10 multi-stranded conductors. Take a look in the Vendors Bazaar.
Blacksheepkable
overhang adjustment vs. twisting in slots ilewis33 Analogue Source 2 17th March 2009 01:55 PM
Twisting and Braiding Cables ralph-bway Multi-Way 19 29th December 2008 09:09 PM
Twisting Wires....which ones ? redrabbit Power Supplies 2 24th February 2008 06:47 PM
Twisting transformer wires? Dominick22 Chip Amps 29 1st June 2006 10:34 PM
Litz Braiding Power wires inside chasis... TaaJ Chip Amps 0 27th October 2004 10:48 PM
Page generated in 0.08175 seconds (74.49% PHP - 25.51% MySQL) with 10 queries
