| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I may build a Pass F1 and want to mount the fets on a 1/4" 2"X12" copper block as a heat spreader attatched to the heatsink. But the surface is rather rough. I figure I would need
to remove about 1/100" to make it smothe and flat. Any easy way to do this without expensive tools? |
#2 |
Sandpaper
#3 |
silicon carbide paper. called wet or dry and also called wet and dry.
Easily available in grades from 180grit to 600grit. 1000grit and 1200grit also available. Use it wet, after removing most of the imperfections and make sure the sheet of W&D is on a flat surface.
regards Andrew T. |
#4 | |
Banned
If you have ever tried using car bodyfiller you will understand. You need a flat support for the abrasive sheet. w |
#5 |
Thanks for all the replys. That was what I was planning on
just wanted to double check before I started. |
#6 |
Glass sheet to support the abrasive, after you have it fairly flat.
Thick glass... Or a precision metal surface, but if you don't have any precision power tools, you won't have that handy... Or, just bring it to a local machine shop and see if someone will take a quick pass on the milling machine with a fly cutter for you... Maybe will cost you a few bux, but save a lot of work... oh, you had best have something as a barrier between the copper and the aluminum... _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#7 | |
Regular thermal paste will do for that purpose, and that's needed there anyway. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#8 |
You are assuming zero contact through the thermal compound, a bad assumption, imho.
And, what about screws? _-_-bear
#9 | |
No, but it takes quite humid conditions, to make anything galvanic happen, and if you have some thermal compound in between the copper and the aluminum, nothing will happen. I know this from experience, as I use copper and aluminum in combination frequently. About the screws, again, you need to add water to the equation, and quite a bit of it, so a little grease, and it's gonna be fine as well. Magura
#10 |
I think you are incorrect.
But if you count the life of the unit in terms of a relatively short span - like most products today - ur ok. I'd still be very cautious about copper and aluminum (or other metals) being in contact even with the grease... Ymmv. _-_-bear
| Question for Metal Experts | Bengali | Construction Tips | 13 | 6th August 2009 05:13 AM |
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| DoD Death Metal Pedal mod question | MrGuitardeath | Instruments and Amps | 8 | 8th December 2005 10:36 PM |
| Page generated in 0.10034 seconds (79.67% PHP - 20.33% MySQL) with 10 queries |
