Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 11th February 2009, 12:52 AM   #1
SMOTH is offline SMOTH  Canada
Default Notch EQ help?
Hello all, this is my first thread! I wasn't entirely sure where to post it, so I threw it here.
I'm building a stand alone Frankenstein spring reverb circuit, part tube, part transistor and part op amp- I'm not quite happy with the tone of the reverb and want to add a simple EQ circuit where I can actively add some more treble. Ideally, I'd like it to have 2 controls; a cut/boost dial and a frequency sweep dial. Unfortunately, I don't yet know enough to design one myself, and an hour searching the web has turned up very little.
Was wondering if anyone here had some suggestions or could direct me to a schematic that might work.
many thanks,
S
Old 11th February 2009, 02:18 AM   #2
Hello SMOTH, From what I read of your post, you want a bandpass filter, as opposed to a notch or band stop filter. An example of a bandpass filter is a Wah Pedal.
Do a google search for bandpass filter and see if that helps you out.
Peace,
Dave
Old 11th February 2009, 02:29 AM   #3
Iain McNeill's Avatar
...or are you after a Parametric EQ which has a tunable boost/cut with adjustable Q?
like this?
http://www.geofex.com/Article_Folders/EQs/paramet.htm
Notch filter godless Multi-Way 5 22nd April 2008 09:26 AM
fe 103 notch filter Jhovis Full Range 6 16th April 2007 09:43 PM
Top-notch DAC. Hajime Digital Source 86 30th June 2004 08:07 AM
Top Notch Dac Kit ad010685 Digital Source 2 29th June 2003 10:56 PM
Page generated in 0.06515 seconds (75.08% PHP - 24.92% MySQL) with 10 queries
