| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello everyone! I am in the mists of building a joule thief. In short a "joule thief" is a low voltage power supply for powering leds. A good explanation of it is posted on hack a day.com (here is the link http://hackaday.com/2007/10/10/joule...#comment-62214 .) So I made a large mouser order and got all the stuff I believe i need. I am trying to run the circuit on .2v so this is a specific version of a joule thief.
Could anyone help me read this diagram. http://wiki.waggy.org/dokuwiki/electronics/joulethief (Very Low Input Voltage Step-up Regulated Power Supply) It is written with key board symbols and i am having trouble deciphering it. Will post pictures as i build! thanks! |
#2 |
this forum is awesome! I cant wait to hear some one's reply.
thanks! |
#3 |
Anyone have an idea where i could look for a potential answer?
#4 |
You may have had not many replies, because his schematics are VERY unclear.
ASCII schematics are sloppy, and unreadable. I can't even clearly make out the symbols, and where the diode is suppose to be! If the guy could make a webpage, I don't see why he can't at least take a good hour or so and make a handmade readable schematic in MSpaint to put on it! It appears to oscillate using a transformer which steps up the voltage to drive an LED. Here's an idea: Try making your own. Make an oscillator from one or two transistors and use a transformer of some type to step-up the voltage. Just look online for typical oscillator or astable multivibrator schematics, and drive a transformer with it. You will need at least 1.2V or more to drive your circuit, because silicone transistors on average drop nearly 0.7V just to turn on, so 0.2V is not near enough. |
#5 |
I have done something like that: http://bigclive.com/joule.htm
It works good with 0.5V input, using a normal silicon transistor, or a digital transistor like DTA114... small package and base resistor inside... At the collector of the transistor, you can place a scottkly diode and cap to ground, and you have a stepped-up dc voltage. add a zener diode, and something else, and you have a regulated dc voltage. |
#6 |
like this:
#7 |
Thanks for all the hlp guys!
I have to certainly agree about the lack of clarity on with that web diagram. I had even emailed the author to try to get him to clarify - but got no response. I Was intrigued by his posted circuit because of its ability to drive with such low voltages. 0.2 volts is not very much. You guys are absolutely correct tho - i should experiment myself with the circuit to see what i can do with it. Will try your suggested diagram and get back to you guys! |
#8 |
For 0.2V, you have to use a germanium transistor. They are obsolete, difficult to find, and with very poor voltage and current characteristics... good luck.
Another thing: to obtain a relative small current on 5V rail (example 10mA), you have to drain a lot of current from 0.2V supply (about 0.5A, or more). It's better to use an over-sized transistor...
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| Power Supply Voltage For 5881/6L6 Amp | simonmurr | Tubes / Valves | 2 | 1st December 2009 05:16 PM |
| high voltage power supply | leemajcool | Power Supplies | 3 | 5th August 2007 11:40 AM |
| Salvaged Power Supply (100kb+ pictures) | Killjoy99 | Parts | 8 | 10th May 2005 07:14 PM |
| Page generated in 0.09778 seconds (75.48% PHP - 24.52% MySQL) with 11 queries |
