Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th February 2009, 09:33 PM   #1
Havoc08 is offline Havoc08  Denmark
Send a message via MSN to Havoc08
Default Dead PSU.. help needed
I have a non-standard PC PSU in my HTPC which now refuses to boot the pc. It delivers enough power to spin some of the fans and light the LEDs on the motherboard, but thats it.
It makes a faint, high-pitched whining noise when turned on.
Any ideas of what to check/measure and what to change?
Its odd-factor so a new one costs $$$$
Thank you
Old 5th February 2009, 10:15 PM   #2
Banned
Today's standard desktop PC PSU produces the following DC outputs: +5V, +3.3V, +12V1, +12V2, -12V and standby 5V.
Your first task is to check for these outputs. Checked the fuses, if any?
The chances of fixing this by remote diagnosis are small, but take a few good quality digital pictures and post them. By good quality I mean sharp, no camera shake, well lit (not flash) and detailed enough to read the markings on the components.
Manufacturers name, serial number?
w
Old 6th February 2009, 10:07 AM   #3
I will take some photos and check for bulging caps when I get home.
Also I will measure on all rails to verify voltage.
Old 8th February 2009, 08:16 PM   #4
Went to my sommerhouse instead
But I fiddled with it tonight and it makes a insanely high pitched and high SPL sound which almost gives you tinnitus.
Any ideas about which failing components can make that noise?
Also I measured the voltages and everything seems fine except a blue wire which gives -10,80. I suspect this to be the -12v rail, but is 10,80 too low?
Pictures are comming when the little sucker has de-powered its caps.
Old 22nd February 2009, 03:26 PM   #5
Fixed it myself, but thank you for your interest
Dead Musical Fidelity A100 - help needed!!! cchean Solid State 11 29th November 2012 07:11 PM
Help needed ! Inter M R300 schematics needed ! alexclaire Solid State 30 9th September 2009 06:14 AM
New Inf. Primus 150- dead tweeters in both - advice needed nyindallas Multi-Way 1 1st August 2007 12:18 PM
URGENT! Dead Time Needed for Discrete Gate Driver defragmenter Class D 6 14th June 2005 06:02 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
