Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Current best Schematic/PCB Software in the ,000 USD and under range
Old 25th January 2009, 09:38 PM   #1
alvaius is offline alvaius  Canada
Default Current best Schematic/PCB Software in the $2,000 USD and under range
Hello everyone,
I am looking for suggestions on what anyone would consider the best under $2,000 pcb/schematic software. I have used a lot of the semi-expensive stuff, Altium/Mentor PADS, but have a need of my own LEGAL copy for some stuff I am doing.
I can not use something like PCB Express as I need portability between where I sent my files out and may have some requirements that PCB Express can not meet.
It looks like Eagly may be one of the few real options for Professional s/w in this range. Any other ideas?
Alvaius
Old 25th January 2009, 10:06 PM   #2
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Eagle all the way.
Old 25th January 2009, 10:36 PM   #3
BrianL is offline BrianL  United States
The TINA version at roughly $1k has a PCB layout package included. I've used the SPICE portion but have not yet tried the PCB portion.
www.tina.com
bel
Old 26th January 2009, 11:33 AM   #4
Pjotr is offline Pjotr
Pjotr's Avatar
If you are used to Protel (now Altium) then a good alternative is Proteus from Labcenter: http://www.labcenter.co.uk/products/pcblayout.cfm Cost is a fraction of Protel and is quite powerfull.
Eagle is also a good choice but I favour Proteus as an alternative for Protel.
Old 26th January 2009, 01:48 PM   #5
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Try WinQCad. I've layed out and fabbed several boards with it, never had a problem. If you have to do any autorouting, WinQCad is amazing, beats the snot out of PADS on that.http://www.winqcad.com/
Old 26th January 2009, 08:15 PM   #6
Pjotr's Avatar
Interesting, never seen that software before. It looks good for that price. How does this package handle polygons? My main core is power electronics and good polygon handling is mandatory then. IMHO on the edge of polygons DXP2004 (Protel) stays unsurpassed, not easy to manage though.
Old 26th January 2009, 09:39 PM   #7
One of my concerns with EAGLE is not being able to export the designs later if I move to likely Mentor/PADS when funds suffice. Any thoughts?
Old 27th January 2009, 04:15 PM   #8
bwaslo's Avatar
You can draw polygon shapes, not sure what other functions like that might exist in it or other packages. I didn't use much polygon, just ground flooding (which it does quite well).
Best way to check is to download package, it's free to try (up to some # of pins)
Old 27th January 2009, 04:29 PM   #9
hifimaker is offline hifimaker  United States
hifimaker's Avatar
Have you seen Multisim from National Instruments?
Integrated SPICE, schematic capture, and board design. Highly renowned product.
http://www.ni.com/multisim/
-David
Old 27th January 2009, 04:49 PM   #10
lineup is offline lineup  Sweden
lineup's Avatar
I recently changed my harddrive.
This meant a new copy of Windows XP and I had to install a lot of software again.
I had run MultiSim 9 at my old harddrive.
I decided to 'upgrade' to Multisim 10 now.
So I did a search for MultiSim10 torrent and selected the most promised cracked version for download.
Went well and I could install this pirated shared version easily. By instructions.
Now, I could convert my old collection SPICE SIM models from MultSim 9 library and add them to my new MultiSim database.
There is a conversion function to use.
MultiSim 10 has more transistor models than MultiSim 9. Evenso there are many usual audio transistors you have to search (this forum) and add using the Component Wizard.
Some softwares has got more audio transistor models. Some less.
The issue for audio works in special, I have found is not to find good working Spice software,
but to find useful transistor models to run and get good and fairly valid results from your simulations.
Lineup Regards
lineup
Current best Schematic/PCB Software in the ,000 USD and under rangeHide this!Advertise here!
schematic software east electronics Solid State 25 16th October 2008 08:58 AM
Schematic software Sparky OR Everything Else 11 1st January 2008 10:07 PM
Schematic Drawing Software wiredmonkey Solid State 20 19th September 2007 03:12 PM
Schematic software part libraries? triden Parts 4 18th February 2006 04:14 PM
schematic drawing software steven344 Everything Else 12 22nd December 2005 09:41 AM
Copyright ©1999-2017 diyAudio
