| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Thread Tools |
I want to purchase some of my kitchen appliances in europe and use them here in Canada.
We are on 120/240 60hz AC what i am looking at is rated for 230V 50hz the problem is we do have anything available here all old type products, nothing innovative and on top of that, they throw in 2-300% price tags on the same model appliances what i am mostly scared of is the Induction cooktop looking also at a steam oven and some electrical grills/ceramic cooktop what do you think ? |
#2 |
Shouldn't be an issue. Fundamentally, this comes down to the volt-second product, which is the area under the curve for the sine wave. So if you integrate 230V, 50Hz, you get a number, which is directly related to the magnetic field strength (might not be using exact terminology, here, it's late). Perform the same integration on 60Hz, and you are actually permitted to use at a slightly higher voltage. So, you can use a 50Hz appliance at 60Hz, but typically will want to increase the voltage a bit; 240 seems like a good number. The concern is one of magnetics. You can also use a 60Hz device at 50Hz, but then need to de-rate the voltage so you don't saturate the iron.
Keep in mind, though, that things like timers/clocks will no longer be calibrated in seconds. There could also, I suppose, be some electronically controlled devices that are calibrated based on frequency. Maybe a bare bones phase controlled heater that is calibrated in degrees. But that's a little esoteric. |
#3 | |
GlassFET
If you have a rotisserie in it, it will likely turn faster, since they most often than not use synchro motors. It could be noisier because of that too. Cheers!
-= Gregg =- Hobby and communites: GeeK ZonE - Commercial site: classicvalve.ca - diyAudio Blog - GeeK's Bench |
#4 |
ok i see
thank you do you guys believe that there could be any danger for dommaging the appliance? most of the euro appliances are for 50hz nah ? so why would an european only model have a jumper for frequency ? unless some countries i do not know of , use 60hz there i usually get 117-120VAC on my outlet so i should have 235-240VAC when i'll use both ends do you think that the control boards use AC ? i thought that most control boards were DC based, in wich case 50-60hz wouldn't matter much no ? neway i'll look forward to import most of my appliances, there is just plain nothing available here ![]() (i'll buy the fridge/freezer locally of course )
| Thread Tools | |
| how to 60hz to 50hz 7KW or more reliable but cheap!?? | JinMTVT | Everything Else | 13 | 12th August 2009 03:23 AM |
| Converting 50Hz to 60Hz??? | Antripodean | Parts | 26 | 18th April 2009 07:39 AM |
| Using 60HZ equipment in 50HZ environment. | abmoggy | Solid State | 11 | 26th July 2005 05:12 PM |
| Linn 50hz to 60hz? | protos | Analogue Source | 3 | 24th June 2005 07:35 PM |
| 50hz on 60hz | lawbadman | Power Supplies | 10 | 21st April 2005 01:26 AM |
| Page generated in 0.08747602 seconds (73.10% PHP - 26.90% MySQL) with 10 queries |
