Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th January 2009, 12:57 PM   #1
reiver is offline reiver  United States
Default Is there a substitute for "Flux-0ff' spray?
I have a couple of amplifier audio boards that have some flux gunked up on them (too much soldering).
But noone in my area sells Flux-off anymore, including Radio Shack. Can I substitute another solvent like Brake-cleaner without destroying anything? I know most electrical parts are rated to take a variety of solvents.
Ideas?
Old 13th January 2009, 01:15 PM   #2
Elvee is offline Elvee  Belgium
Isopropanol works well, leaves no whitish residues, and is safe, even with sensitive parts such as PS capacitors.
You can find it in a spray form as a whiteboard cleaner.
Old 13th January 2009, 01:24 PM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I've been using lacquer thinner with good results for years.
Old 13th January 2009, 01:40 PM   #4
Isopropyl (rubbing alcohol) is fine, and won't destroy plastics, especially polystyrene caps, like stronger solvents.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 13th January 2009, 02:35 PM   #5
rcavictim's Avatar
Yes, it is what a skunk uses! Nobody knows better how to say "Flux-0ff" than a skunk!
But seriously, I use a spritzer bottle with a plastic straw from a WD-40 can or similar hot glued to the nozzle and filled with 99% isopropyl alcohol from the drugstore and a nylon brush like a toothbrush. Saves a ton-o-money over the spray can products.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 13th January 2009, 04:38 PM   #6
Default Thanks
Thanks everyone, I'm glad I didn't waste money on mailordering some flux-off.
I have a bottle of 99% iso on my shelf, I know what I'm doing tonight....
-Bryan
Fix spray paint run on MDF box? samtny Multi-Way 6 28th January 2008 10:24 PM
spray gun's paint larksp Multi-Way 3 3rd June 2007 02:49 PM
Wanted: SEAS H211 1" dome tweeter or close substitute GordonW Swap Meet 0 2nd November 2005 05:13 PM
conducting spray Stefano Planars & Exotics 6 28th January 2004 05:00 PM
JFET Buffered Gainclone-substitute for "SK170 hifileslie Chip Amps 10 21st August 2003 06:09 AM
Page generated in 0.07926 seconds (77.82% PHP - 22.18% MySQL) with 10 queries
