Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Odd Windows XP boot problem
Old 11th January 2009, 04:15 AM   #1
woody is online now woody
Question Odd Windows XP boot problem
I used Partition Majic to copy one drive to another. I then disconected the first drive and used the copy and it acted fine
for a few weeks. Now after I turn the computer off it starts to
load windows and either reboots or freezes. But if I go into safe
mode or get to the safe mode login screen then chose to restart
the computer will boot up. I don't need this drive and still have
the original which works fine I just wonder what could be causing
this problem any ideas?
Old 11th January 2009, 11:24 AM   #2
Geek is offline Geek
Geek's Avatar
With Windows 98, this could be fixed by opening a DOS prompt and entering "fdisk /mbr" (minus quotes).
Can any XPerts here confirm this for XP?
(please don't do this until confirmed)
Cheers!
Old 11th January 2009, 01:59 PM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Try running chkdsk from the recovery console.
http://support.microsoft.com/kb/314058
/Hugo
Old 11th January 2009, 02:17 PM   #4
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
MBR may not be a problem because the safe mode would not start then.
It may be in order for the new hard disk drive not to cause the problem.
Since you said it, this worked until a time.
There may be a software problem, into which a not desired guest belongs, virus, bugs, worms etc.
A motherboard may be or power-supply unit problem.
It is necessary to look at the event log in a safe mode of operation, gives a clue maybe.
It is necessary to put back the original hard disk drive, excluded with this the hardware problem. The new hard disk drive may be the reason of the mistake possibly of course.
Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 12th January 2009, 12:52 AM   #5
Chkdsk did take care of it thanks. I guess I just had a slightly corrupted file I turned my back a moment and when it was through it worked.
Odd Windows XP boot problemHide this!Advertise here!
The whole boot/trunk for E.B.S mikee55 Car Audio 3 5th September 2007 10:33 AM
Computer boot up problem...help! ashok Everything Else 20 3rd June 2007 01:58 PM
PC doesn't boot Devil_H@ck Everything Else 41 8th June 2005 09:41 PM
Boot build Ryancowe Car Audio 0 1st April 2004 02:40 PM
Copyright ©1999-2017 diyAudio
