| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi im on the way of choosing a function generator.
I want one that is able to output a square and sine wave down to the hertz in accuracy...the accuracy is important. I dont want the frequency to drift more than within one hertz during operation either. I will output a frequency of for example 451 kHz (square and sin waves). I want it to be able to produce totally positive offset square waves between for example 1 volt to 13 volt peak to peak. i have thought about buying a "Victor VC2003" it has specs as follows and I don't know how to interpit them: Output scope of frequency 1Hz~3MHz Frequency accuracy ±(5×10-5+10mHz +1) Square wave distortion 20ns Output amplitude 16Vp-p DC deflexion ±6.4V Output wave Sine wave , square wave distortion Harmonic distortion -40dBс Square wave distortion 20ns Function output impedance 50Ω Output amplitude 16Vp-p DC deflexion ±6.4V Inside amplitude modulating frequency 400Hz, 1kHz Inside amplitude modulating depth 1%~100% Outside amplitude signal frequency response 100Hz~100kHz Outside amplitude modulating input impedance 600Ω Frequency sweep time 0.02s~5s Outside frequency measurement sensitivity 250mVrms Dimension 270 ×215 ×100mm Weight 1.9kg Power AC 220V/110V 50Hz/60Hz Thanks for all the help |
| Function Generator? | TheDriver | Parts | 4 | 18th August 2008 09:46 AM |
| Looking for an used function generator | Eva | Swap Meet | 0 | 21st February 2008 06:56 AM |
| function generator | d1camero | Tubes / Valves | 2 | 27th January 2008 06:26 AM |
| Have you seen my new function generator | jwb | Pass Labs | 1 | 28th August 2002 06:06 AM |
| Page generated in 0.06705 seconds (73.88% PHP - 26.12% MySQL) with 10 queries |
