Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th December 2008, 12:37 AM   #1
Default Laser target
I'm looking for a way to recognise when a green laser pen "gun" is shone at a "target" circuit. If any of you have ever been to anywhere like Laser Quest, Megazone or Quasar, you'll know what I'm talking about.
The first idea I've come up with is an array of LDRs and transistors tuned with pots to the point where only the high intensity of the laser turns it on. The problem is that this has to work outside and not be tripped by car headlights and suchlike. Furthermore, this must operate correctly at distances over 800m.
The best solution I can think of is to use long/medium wave radio and a tone detector to enable the LDR target receiver. The "gun" would turn on the laser and transmit a tone over radio. The "target" would receive this signal and switch on the LDR circuitry, allowing the target to register the shot.
Any circuit ideas?
Old 29th December 2008, 01:09 AM   #2
I thought most of those systems, even the good ones, used an IR laser for the "shot", and just a low intensity green / red laser for visibility?
Old 29th December 2008, 01:50 AM   #3
If you can modulate the laser it's easy to detect it. That's how almost all commercial conveyor line sensors and such avoid being tripped by ambient light, including modulations from fans and and headlights and such. If you can't modulate the laser your chances of success are much lower. You'll have to resort to narrow band optical filtering to reduce sensitivity to other light sources, and getting the trip level right will be near impossible unless the system is hard mounted with fixed alignment.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 29th December 2008, 09:47 PM   #4
I'd be using a standard green laser pen with a relay hooked up to the switch, so no modulation. It's not really an issue though as long as I'm using some other form of enable signal. If the target LDR is only switched on whilst it is receiving the radio signal (i.e. whilst the "gun" fires - a 300ms period at most) it is very unlikely to get hit with a enough light to cause it to be tripped. This equipment will be used at night in rural and village areas, so there will be very few cars around. I think the trick will be to find an LDR that has a very low sensitivity, or one that does not reach max/min resistance until a very bright light hits it.
As far as IR for the shot goes, I don't think it'd work over distances of 800m. To get the distance I'd need very bright IR LEDs, but then I'd loose all precision - I don't want to have the sensor tripped if I miss them by 2 inches, let alone 2ft.
The reason I suggested using AM radio for the enabling signal is that it's pretty easy to build a portable battery powered AM transmitter that gets ranges of 1km, and as long as I'm only transmitting short beeps on an unused frequency there's no licensing issue.
Anyone know of a circuit I could use for an AM transmitter? I've found plenty of suitable FM ones (this one in particular, using the larger PCB option), but not any AM ones. FM is much more highly regulated and I don't want to get caught spamming local FM radio with bleeps.
Old 29th December 2008, 09:59 PM   #5
What makes you think you can't get IR lasers? And by insisting on not having modulation (why not have your laser hooked to a modulation circuit hooked to your relay hooked up to the switch?) you're inventing a new set of problems.
If you do go this way, remember to put a green filter over the LDR to reduce the odds of it being tripped by other random bright things.....obviously, anything bright and with enough green in the spectrum will trip it anyway.
Old 29th December 2008, 10:34 PM   #6
Another thought - LED's make quite a good narrow spectrum light detectors, if you need a very small target. A green LED typically detects light best at about 560nm, and adequately well at the typical "green" laser wavelength of 532nm.
Of course, the currents are on the order of microamps, so you'd need an amplifier, but audio grade cleanliness is hardly required here.
Old 29th December 2008, 10:37 PM   #7
I've not dealt with modulation before. I'm assuming the idea is to use an oscillator to switch the laser on/off and then get the receiver to detect the correct pulse frequency. Any circuit ideas? I've got no idea where I'd even begin to detect the right pulse frequency.
Old 30th December 2008, 12:43 AM   #8
dangus is offline dangus  Canada
Chips like the NE567 are designed for tone detection.
Old 30th December 2008, 01:05 AM   #9
I'd be interested to see an example of this. Transistor amp or opamp? Would it work if I put a group of LEDs in parallel? It'd be very cheap and easy to put an array of 10x10 green LEDs together, and it'd be a perfectly sized target.
I've simulated a simple latch circuit for my target - image attached. The reset key is literally a key switch (this will be a paintball style game - one hit and you're dead) so that players cannot turn themselves back on. The alive signal LED will actually also be linked to the attached gun's power, disabling the player completely until the key is used to reset them.
Old 30th December 2008, 01:55 AM   #10
Simulated a simple amplifier based on opamps that can effectively switch on a transistor with a very small current input. Schematic attached. I've simulated the circuit by swapping the LED array out for a fixed current source of 2.5uA and it seems to work perfectly.
EDIT:
Just as a side-note, the lasers I've opted for are 532nm with a power of 30mW. Only £20 each too!
Target Frequency Respons to design to arc2v Multi-Way 2 29th May 2007 12:38 PM
Target values for a headphone amp? GD3 Headphone Systems 2 17th August 2006 08:06 AM
Target SD-2800 enter Solid State 2 21st January 2006 11:45 PM
Target SPL? MethMan Multi-Way 2 6th January 2006 04:32 PM
Page generated in 0.10687 seconds (80.93% PHP - 19.07% MySQL) with 11 queries
