Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 21st December 2008, 04:49 AM   #1
tcat is offline tcat  Australia
Send a message via MSN to tcat
Default HELP ! how to make an air chamber of 25L
I have brought some components to put together some floor standing loudspeakers. I have a 200w rms crossover wich i idealy need to change to a 500w rms powered crossover. so i also have a 50w rms alumium dome tweeter, 70w rms mid and a 150w rms 300w max woofer.
everything is and can be wired easily but i am unsure of how big a 25 Littre chamber is or could be, it would be greatly appreciated if someone could help me out here or give me some suggestions, thanks heaps.
here are the tech specs if you need them to
Specifications:
• Nominal impedance: 8 ohms
• Power handling: 150WRMS
• Sensitivity: 86dB (1W at 1m)
• Qms: 2.15
• Qes: 0.57
• Qts: 0.45
• Vas: 30.6 litres
• Fs: 35Hz
• Tuning frequency: 35Hz
• Recommended enclosure volume 25 litres, ported.
• Dimensions: mm
- A= 243
- B= 219
- C= 202
- D= 96.5
Old 21st December 2008, 02:50 PM   #2
with a Qts of 0.45, I consider this driver unsuitable for a vented enclosure.
I suggest you try a sealed box enclosure and use a Linkwitz transform to adjust the bass parameters to suit your room and hearing preferences. But do not try to use +20dB of boost. Aim for <=+10dB
regards Andrew T.
Old 21st December 2008, 10:41 PM   #3
thanx heaps, my knowledge of this stuf compared to you is a little impaired so wats a linkwitz and how do i use it ?
Old 3rd January 2009, 05:45 AM   #4
00600 is offline 00600  United States
http://sound.westhost.com/linkwitz-transform.htm
that should get you started....
Tweeter chamber slogan2112 Multi-Way 3 18th May 2008 05:30 PM
So, what exactly does a compression chamber do?? NV&H Full Range 2 5th February 2006 12:40 AM
Separated or Same Chamber Box? suprastar17 Subwoofers 2 19th April 2005 02:32 PM
DIY anechoic chamber! Snickers-is Multi-Way 33 13th March 2005 07:30 PM
Water chamber sub Guss Subwoofers 42 1st December 2003 01:58 AM
Page generated in 0.07107 seconds (80.02% PHP - 19.98% MySQL) with 10 queries
