Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 4th December 2008, 05:29 AM   #1
Audio Junkie
Zero Cool's Avatar
Default LM317K upgrade?? Higher Current??
I have a large mixing console that uses a Pair of LM317K TO-3 type Adjustable V-regs for the +/- 17V rails. The mixer draws about 1.25 amps from each rail. pretty close to the 1.5amp rating of the 317K device.
I need to replace both regs as a power spike killed them. So i am wondering before i place a purchase, if there is a drop in repalcement rated for a bit more current?? maybe 2 amps or so just to increas the margin.
Early revisions of this supply had a pass device for each side as well at the 317K but at some point they revised the supply and took that part out and changed the board.
Zc
Old 4th December 2008, 06:08 AM   #2
Puffin is offline Puffin  United Kingdom
LM338, 5Amps? Check pin outs though
Old 4th December 2008, 11:46 AM   #3
Audio Junkie
Zero Cool's Avatar
YES!!! that looks to be a pin for pin drop in replacement. specs look nearly identical! Thanks!!!
Zc
“Ideal” power/regulation for higher-current digital-section ICs hollowman Digital Source 0 8th April 2008 04:07 AM
Parallal SMPS to get higher current 1206.sachin Power Supplies 5 29th October 2007 04:37 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
Page generated in 0.06925 seconds (69.99% PHP - 30.01% MySQL) with 10 queries
