| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
I tried a different sort of null test last night on one one of my mosfet/LM317 choke loaded power amp follower thingies. I drove the input from a transformer so it was floating, then put the scope earth probe lead the live input and the scope probe live to the output. That means the only signal read was any difference between input and output. For a 24v p/p driving into 6 ohms resistive there was about 3mV difference just before the onset of clipping, but it was way down in the noise so it was a bit hard to tell accurately. Way better than just trying to compare input and output though.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#12 | ||
Jorge |
#13 | |
Well... I knew what I meant anyway.
#14 | ||
The input network to a typical power amplifier is a mostly resistive load with a small reactive component. This complex load DOES NOT vary in any significant way with loading on the output of the amplifier. If you want to convince me otherwise, show me the math. |
#15 | |
The rising error with frequency most probably is related to uncomplete nulling caused by freq response and/or phase response differences between channels. This, ultimately, is the limit of the available null even if there is no "traditional" distortion, as I am sure you know. Unless you want to go to really complex nulling correction networks. Jan Didden |
#16 | ||
A PERFECT null would show as zero reading on your meter.
Part of my point was, despite a rolling off meter response you are getting increased reading with increased frequency - IOW the matching error is actually worse than your meter indicates. Go back to bed. Eric.
I believe not to believe in any fixed belief system. |
#17 | |
If you load the amplifier, you make the null worse (because you bring out more of the sorts of errors you suggest), which could mask subtle differences between cables. |
#18 |
diyAudio Senior Member
From what I gather, Eric's refering to "spitting" in a previous post points to reflections of the signal back into the cable at the receiving end. Cable reflections can cause distortion of interface and backwall echoes, and in extreme cases (cables on the order of 30 meters/100 feet or greater) they can even result in large spurious signals following desirable signals at an interval equal to the electrical transit time in the cable. No transmission line is ever prefect, hence the phenomenon can rear its ugly head in audio/video setup causing image ghosting (video) or said "spitting" or reflections in audio. So, when setting up a test rig you need to be sure of what you're doing. If not you're actually misleading yourself. Nothing's ever easy. Cheers,
Frank |
#19 | |
Jan Didden |
#20 | ||
And using cables of 30 meters...is a little unusual!!....I think!! Quote:
Jorge |
| Null Test | tbrooke | Pass Labs | 6 | 12th May 2009 04:51 PM |
| looking for null circuit | jaudio | Chip Amps | 17 | 2nd December 2008 08:54 PM |
| take a look at my fr plots and tell me what you think about that null | pjpoes | Multi-Way | 14 | 19th July 2008 03:44 AM |
| Carver + null difference test + how can i copy a amp | umutmt | Analog Line Level | 2 | 4th September 2007 04:03 AM |
| Page generated in 0.15225 seconds (84.87% PHP - 15.13% MySQL) with 11 queries |
