diy iPhone 3G charging/lineout Adapter - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th December 2008, 03:27 AM   #11
DC Dave is offline DC Dave  United States
DC Dave's Avatar
Haven't had a chance to try it yet. I'll keep everyone posted.
Old 6th September 2010, 08:58 PM   #12
Havoc08 is offline Havoc08  Denmark
Send a message via MSN to Havoc08
how did it go?
Old 6th September 2010, 09:34 PM   #13
DC Dave's Avatar
Works great with my iPod, but I didn't get the line out to work with the iPhone. At the time this thread was started, there wasn't much on the market, but now there are different adapters and cables to choose from. I'm currently using a Pocket Dock successfully. Not diy, but it works.
Old 7th September 2010, 03:06 PM   #14
hmm okay. I want to make a custom dock with lineout and charging and syncing capability.
Old 25th September 2010, 12:38 AM   #15
I just got a dock from amazon that claimed to be for the iphone 3g. I used it for the ipod touch and the touch plugs into it just fine. One problem was that I got a bad hum when listening to music and charging at the same time. I opened the case up and also discovered that the tip of the 1/8 audio jack was being tied together with pins 3, and 4 ( im guessing the audio left and right), the center ring was being grounded, and the ( what should be ground ) back ring on the plug was open and not connected at all.
All I see is one 75.3k ohm resistor connected to ground, and then wires connecting the back plug to the plug going to the ipod touch / iphone.
Old 2nd November 2010, 01:01 PM   #16
I have not yet found a solution to that problem other than apple designed the iphone 3g wrong with common ground for USB and audio.
I guess a ground loop isolator would work.
Old 2nd November 2010, 01:07 PM   #17
I solved the problem. It was a defect in the design if the dock. I made some cuts on the pcb and some jumpers and it works great now. I have true stereo Audio out and I can charge with out getting hum.
charging capacitor joeyd71 Car Audio 4 4th April 2009 08:24 AM
Blaupunkt lineout pin-out harrygrey382 Car Audio 2 12th September 2008 10:11 PM
Help with charging Li-ion cell EWorkshop1708 Power Supplies 14 29th May 2008 03:59 PM
Roland Cube 30 lineout mods. papparay Instruments and Amps 1 13th October 2005 08:44 AM
Copyright 1999-2017 diyAudio
