Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th December 2008, 01:35 PM   #21
Pjotr's Avatar
Normal vacuum tube filaments are designed to be driven by a voltage source. Their dynamic impedance is fairly high, that is, the current does not change much with varying voltage. Driving it by a current source gives unreliable heating power. Only filaments designed for series power (like in direct mains powered TV sets) will do proper driven from a current source.
Just my 2Ct
Old 13th December 2008, 11:45 PM   #22
Originally posted by Pjotr
. . . . . .Driving it by a current source gives unreliable heating power. Only filaments designed for series power (like in direct mains powered TV sets) will do proper driven from a current source.
Just my 2Ct
Hi Pete !
What you're saying is interesting , but it makes it curious that the verdict from those who have powered tube heaters and filaments from both Voltage and Current regs is almost unanimously in favour of Current regs. If you are correct (and I don't doubt you are) then I wonder if the two things are unrelated and current regs sound better for a different reason.
Old 14th December 2008, 10:48 AM   #23
Pjotr's Avatar
For that your reasoning is probably right At low frequencies the filament supply should behave as a voltage source to ensure proper heating power. But the thermal time constant of the filament is pretty long, especially with indirect heated tubes. So the voltage source behaviour is not needed at higher frequencies and indeed an inductor in series will isolate the supply the higher the frequency goes.
I have no real experience how this will sound but my proposal is: Make a regulated supply and make the gain of the control loop dropping down with frequency. This will simulate a psu with inductive behaviour. You can make the frequency corner of the control loop quite low, but if you make is too low you get overshoot and instability at start up.
Old 7th February 2009, 01:39 PM   #24
jkeny is offline jkeny  Ireland
Banned
Guys,
Is this a real gyrator then? I'm looking to drop about 10V from a 72V DC for use in a 150W amp. I considered the gyrator as a way to do this & get ripple reduction while I'm at it. I just put an additional 12 V zener (1N4742) in there to act as a regulator also.
Old 19th February 2011, 07:58 PM   #25
korneluk's Avatar
Here's another example:
For the full text and explanation follow the link:
Capacitance Multiplier Power Supply Filter
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
can one buy a head phone "wireless" converter cord? joywrex Parts 0 14th June 2003 04:41 PM
Page generated in 0.07992 seconds (72.45% PHP - 27.55% MySQL) with 11 queries
