have you tried www.archive.org
looks to be well covered, a retrieved page example:
http://web.archive.org/web/20041205215800/www.wenzel.com/documents/reducing.htm
Here it is
and this page of the site is working:
Finesse Voltage Regulator Noise!
http://www.wenzel.com/documents/finesse.html
I see most of it is there in library
http://www.wenzel.com/library1.htm
Home > Library > Time & Frequency Articles
Frequency Synthesis and Conversion
Waveform Conversion
Two Diode Odd-Order Multiplier
Phase Locking and Tuning
PLLs using ULN Oscillators Includes info on Type-2 loops.
Switching Diode Frequency Doublers (pdf, 66k)
Unusual Frequency Dividers (pdf, 35k)
HCMOS Gates Make Frequency Multipliers (pdf, 27k)
Choosing a Frequency Multiplier's Waveform (pdf, 32k)
Frequency Tripler using the CA3028 (pdf, 15k)
Simple Divide-By-N using '161s (pdf, 9k)
A Sub-Picosecond Phase Stability Frequency Multiplier
Phase Noise/ AM Noise
Frequency Difference Divider The opposite of a frequency difference multiplier?
Low-Cost Phase Noise Measurement
Phase Noise, Harmonics and Sub-Harmonics
Low Noise Amplifier for Phase Noise Measurements (pdf, 33k) Features less input noise than a 50 ohm resistor.
Audio Noise Sources for Generating Phase Noise Generate white and flicker noise.
Low Phase Noise Systems - Hints and Tips
VHF Oscillator and Multiplier AM Noise
Oscillator Circuits
Tiny Crystal Oscillator (pdf, 13k) High-stability gate oscillator uses two, 5-pin SOT packaged devices.
Low Distortion Crystal Oscillator (pdf, 19k)
Power Supply Circuits
Cockcroft-Walton Diode Voltage Multipliers (pdf, 36k)
Finesse Regulator Noise
scott wurcer said:I have followed John's stuff for years and I have emailed him a couple of times about his magazine column. This site was packed with great stuff, I hope it returns better than ever.
http://www.wenzel.com/documents/circuits1.htm
Thanks guys, I'm sure I can recreate much of it. I was more disappointed at the thought of one of the "good guys" maybe throwing in the towel on new contributions. The stuff on DIY Geiger counters for instance was pretty unique and way out of the box at times. Using the Thorium decay generated leakage in an ordinary neon bulb as a high value resistance, neat stuff.
I thought of him as a sort of Mr Wizard kitchen sink style DIY, as opposed to borrowing CNC milling machines, etc. Don't get me wrong there's a place for both.
- General Interest
- Everything Else
- Wenzel pages gone.
