Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th November 2008, 11:32 PM   #1
N1ESE is offline N1ESE  United States
Default Anodizing Question
Does anyone know if the anodizing process reduces the conductivity of aluminum? I'm wondering if an aluminum chassis would still make for a good ground point if it is anodized.
- JT
Old 17th November 2008, 11:48 PM   #2
Aengus is offline Aengus  Canada
Aengus's Avatar
Anodised portion is an insulator. If you want to use an anodised chassis as ground, you have to scrape away the anodisation at the connection point. Typically, one uses a bolt with a star (lock) washer to dig into the chassis as well.
Regards.
Aengus
Old 17th November 2008, 11:49 PM   #3
That's what I thought and wanted to confirm. Thanks mate.
- JT
Old 18th November 2008, 12:28 AM   #4
Stuart Easson's Avatar
Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default oxidisation
IIUC exposed aluminum will oxidise and eventually render itself partially or completely non-conductive. The anodisation process simply makes the layer of non-conductive material much thicker and pretty.
Thus I think the step of using the star washers is actually needed even on what look like 'shiny' surfaces, if a good connection is to be maintained.
Stuart
Old 18th November 2008, 12:33 AM   #5
Default Re: oxidisation
Yup, star washers are a given on all ground source materials. I just needed clarification on how much of an insulator the anodizing process creates.
Old 18th November 2008, 12:58 AM   #6
sam9 is offline sam9  United States
sam9's Avatar
Allodyne (sp?) is conductive and often used instead of annodizing just for that reason.
DIY Al anodizing - cause of this trouble Steerpike Everything Else 13 5th June 2009 05:22 PM
anodizing nyman Everything Else 2 8th March 2005 09:51 PM
Anodizing Power Supply Question RobPhill33 Everything Else 17 28th February 2003 05:25 AM
DIY Anodizing Andrew Steele Everything Else 11 30th May 2002 09:49 PM
Anodizing doktor Everything Else 7 16th April 2001 08:05 PM
Page generated in 0.07493 seconds (75.52% PHP - 24.48% MySQL) with 10 queries
