Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 24th October 2008, 05:19 PM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Question 2SK127 -- what to use them for?
I once bought couple of plastic bags of some transistors. The seller said they were in-house marked 3904 and 3906. Yesterday needing some cheap PNP switches I opened the bag and found that no way they are BJTs, they behaved like N-type JFETS.
They marked like:
$127
5126
O
where $ I used instead of National sign.
I've searched the web and found that indeed there were such 2SK127 N-type JFETs, but still can't find any details.
The question is, what they are best for?
NPN transistors are marked as:
4500l
3500
EBCi
They are not Darlingtons, and Beta is around 150.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 25th October 2008, 03:16 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
2SK127. They are LF FET transistors (not low-noise) but Cis, Crb is low.
Takes 50 Volt! The gm is Minimum 4mS
Here are some data:
http://www.minor-audio.com/data/2SK/2SK0101-0200.htm
At the same website this guy has lots of stuff/schematics
dealing with NO-NFB amplfiers
http://www.minor-audio.com/bibou/bibou.html
For example this:
NO-NFB MOS-FET 15W パワーアンプの製作
The 15 Watt Amplifier
+-35 Discrete Regulator for the MOS-FET 15 W
Webpage: http://www.minor-audio.com/bibou/NO-...NFB_main2.html
lineup
Old 25th October 2008, 04:08 AM   #3
lineup's Avatar
Toshiba 2SK330 is one equivalent to 2SK127
http://www.datasheetcatalog.org/data...shiba/1033.pdf
A look shows most of the data is very much comparable
lineup
Old 25th October 2008, 04:14 AM   #4
Wavebourn's Avatar
Thanks Lineup!
I have more than couple of thousand of good P - type jfets instead of small PNP transistors...
Old 25th October 2008, 05:00 AM   #5
Wavebourn's Avatar
Hmmm.... It's strange, but I've found another info, quite contradictory (mine are P-jfets according to brief measurements, like on your link):
Specsheet from Matsushita Electric Works, Ltd.
2SK127
N-Channel JFET
V(BR)GSS (V)=80
I(D) Abs. Drain Current (A)=20m
Absolute Max. Power Diss. (W)=250m
I(DSS) Min. (A)=12m
g(fs) Min. (S) Trans. conduct.=3.0m
@V(DS) (V) (Test Condition)=10
Status=Discontinued
Package=TO-92
Military=N
From your link:
-50V max, pinout unknown since I can't read hieroglyphs:
It's like earlier I've fried lot of new power MOSFET samples because found a wrong version of datasheet for VN2222 small MOSFET. Later I've found that 2 of them exist, with different parameters and pinouts!
Old 25th October 2008, 10:02 AM   #6
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
50V : 2SK127
80V : 2SK127A
Looks like Sponge Bob has killed another thread.
Old 25th October 2008, 05:09 PM   #7
Wavebourn's Avatar
Originally posted by jacco vermeulen
50V : 2SK127
80V : 2SK127A
And one of them is P, another is N?
By the way, I've found today 2 datasheets both from the same Fairchild, for PN5134. According to one document it is PNP, according to another one it is NPN.
According to my quick test, it is NPN.
Old 25th October 2008, 05:33 PM   #8
Spiny is offline Spiny  United Kingdom
Spiny's Avatar
Originally posted by Wavebourn
From your link:
This translates as
1,Drain
2,Gate
3,Source
Old 25th October 2008, 05:42 PM   #9
Wavebourn's Avatar
Originally posted by Spiny
This translates as
1,Drain
2,Gate
3,Source
Thanks a lot Spiny!
Old 25th October 2008, 05:51 PM   #10
More fun in Nipponese, number 3 reads Sosu.
(i'd think a wanderer of the smooth harmony path would read some hieroglyphics)
Page generated in 0.10327 seconds (82.08% PHP - 17.92% MySQL) with 9 queries
