Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd October 2008, 04:29 PM   #1
neil_kaye's Avatar
Default DIY Power cable
I would like to make a series of affordable power cords for my amps and other gear.
Does anyone know of a good source for reasonably priced (shielded?) power cord and plugs. There is so much chatter around the relative benefits of high end power cable that it is hard to sort through all the noise.
Old 23rd October 2008, 05:18 PM   #2
neil_kaye's Avatar
I did find this article:
http://www.diyaudioprojects.com/Power/diyMains/
Old 23rd October 2008, 05:33 PM   #3
theAnonymous1's Avatar
Default Re: DIY Power cable
Originally posted by neil_kaye
IThere is so much chatter around the relative benefits of high end power cable that it is hard to sort through all the noise.
No need to sort through the noise; just plug your ears.
I understand shielded interconnects, but shielded power cables make no sense at all to me. If you had 6ft long audio interconnects, would it make sense to shield only the last two inches of the cable? Of course not. It also makes no sense to shield the last couple of feet of wire extending from the wall socket.
I would say just make all your power cords out of the same stuff in the wall, but it isn't very flexible.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 23rd October 2008, 05:44 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Faraday Cage may help.
http://www.gearslutz.com/board/geeks...aday-cage.html
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 23rd October 2008, 06:13 PM   #5
jneutron's Avatar
Default Re: Re: DIY Power cable
Man I hate that "miles and miles" argument..
Ground loop current flowing on a shield does not create an internal magnetic field.
Ground loop current flowing on an individual conductor does. (note: that is where the 15 nH per foot number comes from...a shield does not have that)
Run a full differential input with a REAL amplifier design that rejects (or otherwise bypasses) input ground current, and one that doesn't consider the wall outlet ground as a reference.. and I'll agree with your premise.
Otherwise, you are incorrect.
Cheers, John
Old 23rd October 2008, 07:04 PM   #6
Eric Juaneda's Avatar
Default Yarbo GY-7000PW
This one totally change my system's sound.
Price is very nice.
Yarbo GY-7000PW
Eric
Old 23rd October 2008, 07:40 PM   #7
promitheus's Avatar
This shop has cool stuff but they are in Germany.
www.audioconnexion.de
Old 23rd October 2008, 09:55 PM   #8
aardvarkash10's Avatar
Default a question or two for poster #1
why do you want to make your own? Is there something inherently wrong with the existing cables? If so, what, and how have you tested or defined the problem?
Or have you just spent all you can already on oxygen-free (or enhanced...) solid silver (or gold, or any other precious metal) interconnects, and pyrimidic stands of mystical proportions to keep it all off the floor and hence away from stray induced currents and capacitance effects inherent in nylon/wool carpet or solid wood floors? Hmmn? Got the tin-foil hat too? :-\
Or are you just a born tinkerer who is keen to make some cool looking cables you can call your own? :-)
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 23rd October 2008, 10:08 PM   #9
Wavebourn's Avatar
This may be cheaper than a Faraday Cage:
http://www.jensen-transformers.com/iso_aud.html
Old 30th October 2008, 12:04 PM   #10
PaleRider's Avatar
I`m using the 3x2,5kv (mm) EKKJ from this Swedish company; shielded solid core copper in black rubber makes a superb powercable.
Btw; the thickest ones in 6 and 10 kvmm solid makes the absolute ultimate low-end speakercables. Same for tops, but mybe not 10kvmm. Needs an hour of high-level burn-in!
https://www1.elfa.se/elfa~eu_en/cata...do?isQuery=yes
https://www1.elfa.se/elfa~no_no/inde...orecookie=true
Power Conditioner Cable? Evan Robinson Parts 5 25th March 2009 05:54 AM
shielded power cable rkreim Vendor's Bazaar 6 23rd March 2007 02:33 AM
problems with speaker cable as power cable pjpoes Parts 11 14th January 2007 08:24 PM
DIY X1 Preamp Power Cable? CptTripps Pass Labs 2 31st October 2003 01:20 AM
Page generated in 0.10425 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
