| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I am baffled. I recently bought a set of "high-end" speakers. To my dismay I found odd components inside. Naked capacitors! No plastic coating or sheath and connect wires is soldered on at each end. Looks like the foil/plastic is wound onto a plastic bobbin. Is this normal?
Not to mention the CAT 5 cable used inside...
"Dont tell me this skies the limit when there is footprints on the moon!" |
#2 |
Hmmm, I would think either:
- Bought surplus - Custom run - Really el-cheapo caps with the wrapper removed. But if they sound great, that's all moot. Cheers! |
#3 |
Actually some people say that they sound better this way, like they remove the plastic on BGs and stuff. That or they do not want someone coping them.
#4 | |
one can always take the cap out and measure it |
#5 | |
Several of the streaker aficionados from back then are registered active members of this club, some you may be familiar with. A ninkenpoop would just find it odd that an electronic component is insulated with plastic foil, despite that temperature is the main parameter that influences it's very livelihood. Got a picture of the odd components ?
Looks like Sponge Bob has killed another thread. |
#6 |
Hi
I have seen naked caps before. They were for sale in a surplus shop in London. There has been discussion on the internet about the use of naked capacitors and also the use of thin wiring in loudspeakers to improve the sound. Regarding the capacitors it just depends how they sound. You do not mention the approx uf value. It would help to know that. I use plastic where possible and electrolytics where a higher value is required. I add a pastic cap in parallel if used in the mid or high range filter. Regarding the wiring. I just stick with basic engineering. Wiring should be short and thick. I use copper with a silver coating in a ptfe sleeve. How do the speakers sound? Don |
#7 |
Hello all
Thank you for all the replies. Unfortunately I cant post a picture of the x-overs as this might put me in line of fire. The reason for this post is that the speakers sound very edgy.
#8 | |
#9 | |
| Naked Vishay MKP660 film capacitors | Magura | Swap Meet | 9 | 28th August 2009 11:07 AM |
| Naked pictures of Pass | Pete Fleming | Pass Labs | 30 | 9th December 2006 06:39 AM |
| Is naked better ? | Bernhard | Parts | 1 | 28th September 2005 09:29 PM |
| many naked cd players | guido | Digital Source | 15 | 25th September 2003 10:20 AM |
| Page generated in 0.10043 seconds (76.69% PHP - 23.31% MySQL) with 10 queries |
