Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th October 2008, 01:58 AM   #21
Juergen Knoop's Avatar
too much weight myself!
regards
Old 15th October 2008, 05:19 AM   #22
despotic931's Avatar
Send a message via AIM to despotic931
Originally posted by audio-kraut
Then stop soldering
Lead in gasoline was not lead as metal particles, it was lead as tetra-ethyl lead.
The combustion would lead to production of lead and lead oxide, fouling up the engine. Therefore lead was captured by substances "scavenging" the lead and pumping it out with the exhaust.
http://en.wikipedia.org/wiki/Tetra-ethyl_lead
Soldering does not "lead" to the production of airborne lead.
I never meant that soldering would produce airborne lead. I realize I never stated my opinion, and my post made it seem I believed it would, but I was really just proving that lead could become airborne. Granted it's not little particles of lead, but the element's atoms are still airborne, and that's what the post I was responding to was questioning. Hehe, sorry I had to respond to this so I didn't feel stupid.
Old 15th October 2008, 06:27 AM   #23
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
OK. It might be harmfull and it might not.
I would still like to try and remove some of the fumes/smell/lead/whatever.
Do you think that the "carbon filters" that are used in range hoods would do any usefull filtering of the fumes?
Thanks for all the replys and oppinions.
Regards TroelsM
Need more time...
Old 15th October 2008, 06:33 AM   #24
Electrons are yellow and more is better!
peranders's Avatar
How much are you soldering?
If you work in production and solder a lot you should have a good ventilation but for hobby I'll guess it's more hamrful to smoke cigaretts.
If you are worried about lead you could switch over to lead free solder.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 15th October 2008, 07:13 AM   #25
TroelsM's Avatar
Hi.
I'm soldering very little these days, but I'm living with a GF that cares for me, and she gets a bit woried each time there's a "solder-sent" in the apartment.
In order to remove any (small) danger and keep the peace I would like to give it a try a fan+filter-thingy solution.
Yes, its most likely far more harmfull to smoke cigaretts, but what's the point? It would also be pretty bad to eat lead, but I don't do that either.
Regards TroelsM
Need more time...
Old 15th October 2008, 08:49 AM   #26
spzzzzkt's Avatar
I've found that soldering has been irritating my eyes, and that I was getting a nasty taste in my mouth the day after when using lead free solder.
In the end I decided either I get an extractor or give up soldering, so I gave in and bought a Hakko smoke extractor (and Hakko soldering station which is fantastic). The extractor has made soldering a whole lot more pleasant and seems to reduce the level of solder "scent". The GF is happier too.
http://www.hakkousa.com/detail.asp?C...PID=702&Page=1
It's pretty quite in use so I'm not tempted to turn it off when I'm mounting components between soldering sessions.
Old 15th October 2008, 09:48 AM   #27
dangus is offline dangus  Canada
I've also gone with the computer fan (salvaged power supply fan), preferably with a grille on both sides. Run a 12V fan off 7 or 8 volts (from an old cellphone charger) and it is nearly inaudible, but still moves enough air to be helpful. My eyes would get irritated from the flux smoke/fumes when doing a lot of soldering (10 boards in a row).
Old 15th October 2008, 10:08 AM   #28
steenoe is offline steenoe  Denmark
steenoe's Avatar
To get rid of the solder fumes in the apartment, you could do the soldering in the kitchen. Make a workspace on the cooking plates and start the cooker-hood (emhætte in danish), or whatever you call it, on full throttle and you will have clean air.
Old 15th October 2008, 10:15 AM   #29
tinitus is online now tinitus  Europe
I have used half a kilo in the last few years, but its on speakers where more is used, so the fumes doesnt bother me much
BUT, I handroll my cigarets and when having touched the solder, I can tell you that a cigaret taste real bloddy awfull...so I can only advice to wash hands after soldering
Old 15th October 2008, 03:36 PM   #30
As peranders said, whats the reason for not using lead free solder if you're worried? Surely thats a much cheaper and easier solution? Granted that doesnt solve the problem of flux fumes, but you seem more concerned about the lead
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 33.33%)
Copyright ©1999-2013 diyAudio
