Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th October 2008, 08:57 PM   #11
Pjotr's Avatar
Originally posted by Zero Cool
Actaully, this was from a guitar pick up from the 60's so it may not have been new wire! But good to know.
With older magnet wire: If you start tinning from the end where there is a small area of blank copper at the cut, solder will creep slowly under the enamel. With some patience you can sometimes tin it when using generous amounts of usual flux cored solder.
Old 14th October 2008, 12:03 AM   #12
Geek's Avatar
In school we did an experiment and left a 4" (or was it a 3"?) nail in a jar of coke - it was gone in a week
Old 14th October 2008, 12:15 AM   #13
MJL21193's Avatar
Default Re: removing enamel from magnet wire
any suggestions for removing enamel from magnet wire without scraping the wire???
Lacquer thinner. Dissolve the varnish right off of there, then wipe with a cloth or paper towel.
Acetone maybe. Nail polish remover.
Old 14th October 2008, 02:30 AM   #14
diyAudio Moderator Emeritus
Iain McNeill's Avatar
An aspirin eh? That's a non-intuitive trick - must try it.
Hi Greg!, I've noticed that on newer magnet wire as well - good call. If you can get the iron to make contact with the copper - even at the bare end where the wire was cut, you can get the coating to peel back with the solder/flux.
If that doesn't work then I usually just resign myself to several minutes of gentle scraping with a scalpel blade - usually against a bare finger for protection.
MJL: does lacquer thinner work on the polyimide coatings as well? Something like turpentine or are you thinking ketones or some such? I thought I'd tried isopropyl alcohol unsuccessfully but that's a pretty weak substitute.
Old 14th October 2008, 02:43 AM   #15
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Yep, especially fixing dynamic microphones and making microphone transformers when the single error means the total failure.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 14th October 2008, 02:49 AM   #16
MJL21193's Avatar
Lacquer thinner has acetone and toluene in it - a couple of pretty heavy solvents.
I have a sheet of polyimide (Kapton) that I've been unsuccessfully trying to use as isolation pads to try it on. Darn stuff is nigh on impossible to punch a clean hole in.
Old 14th October 2008, 08:57 AM   #17
Geek's Avatar
Hi Iain,
A zip knife works too and is less dangerous
Some careful work with 400 to 800 grit sandpaper is also good on stubborn (read: old) enamel magent wire of tiny gauges.
Cheers!
Old 10th October 2012, 07:42 AM   #18
Post REC
There is one company named International Electrochemical Company which manufactures enamel removers.
I havent tried it.
Old 22nd October 2012, 02:05 AM   #19
Magz is offline Magz  United States
Dremel with a stainless steel wire brush, medium speed - I use it to strip the enamel off litz wire and it works like a charm. Just make sure the brush rotates toward the end of the wire to avoid tangling.
Old 22nd October 2012, 03:23 AM   #20
BudP is offline BudP  United States
BudP's Avatar
For magnet wire that is class B or F (130C or 155C for300k hours) you can use a "weak tea" solution of alcohol thinned, liquid flux from Kester and others. The large amount of alcohol will ablate the coating and the small amount of flux will clean and adhere the solder. You should squeeze the wire in a cloth shop rag made of cotton just to remove the last bit of burned insulation. Set your solder pot for 600 F for this. You will get solder balls from this process, they will splatter. This is the easiest and quickest way to completely strip Litz wire, which you want in and out of the pot in under 5 seconds.
For the armored wires a Rush Brush wire stripper or the trusty metal wire brush in a drill bit are fine, along with scraping with a sharp razor style blade. Boron works too, but that's so dangerous you don't really want to try it.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Interconnects - Magnet wire? otto88 Everything Else 49 7th August 2008 02:49 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
mysterious magnet wire jonathan3233 Parts 4 11th October 2004 02:39 AM
Magnet Wire TaaJ Chip Amps 4 26th September 2004 08:00 PM
best way of coating bare wire with enamel? tom1356 Parts 6 10th October 2003 05:41 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
