Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 7th October 2008, 02:07 PM   #1
polyal is offline polyal  United Kingdom
Default vu meter mod
the FSD of a vu meter is usually no sound to
overloading (-24 to +9 )approx
i need to modify the characteristics so FSD
reads -6 to +3 ( approx ) via a specific or
modified meter driver
can anyone help with suggestions or pointers etc
(this is a DIY proj)
thank you
al saunders
stoke on trent UK
Old 12th October 2008, 08:37 PM   #2
Speakerholic
Cal Weldon's Avatar
Moved to everything else.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 13th October 2008, 11:45 AM   #3
acid_k2 is offline acid_k2  Italy
- zener diode in series to the signal path (cut lower signal)
- op-amp with about 3dB gain, or more..(amplifies remaining upper signal)
- re-drawn of the dB scale
Old 13th October 2008, 01:27 PM   #4
jackinnj's Avatar
One of the linear tech guys did an article in EDN for an 80dB range VU Meter -- with the proper attack and decay times:
Old 13th October 2008, 04:56 PM   #5
@jackinnj
polyal ask for less vu-meter range... from 30dB range to about 10dB range.
Old 14th October 2008, 03:57 AM   #6
Iain McNeill's Avatar
you need gain and an offset - not possible in a passive solution. Something like Jackinnj's posting is about the minimum for accurate VU ballistics. You can also check out Analog Devices - they have all sorts of IC's for this with very good performance.
http://www.analog.com/static/importe...ection_III.pdf
Old 14th October 2008, 12:21 PM   #7
jackinnj's Avatar
You can use a window comparator to set the range -- throw away the data below and above the window and just measure what's contained in between. You can easily do this with an dual comparator and an opamp which has "Shutdown" although most of these are SOIC or MSOP. If you don't want to screw around with surface mount just use a JFET as a switch.
The circuit I provided will get you the right ballistics -- and there are others on the web as well.
Remember that 0 dBm is 1 milliWatt into 600 ohms -- approximately .774 volts --
car RPM meter 2 ido2 Everything Else 2 11th September 2007 08:36 AM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Page generated in 0.08375 seconds (80.97% PHP - 19.03% MySQL) with 10 queries
