It is used in classified applications, so you don't have info on it.
John this is nonsense, it embarasses me to read that. Really.
How can anything be classified that you can buy on any street corner, sort of?
jd
Nah, lets try a glass of Dom Pérignon to keep John going.
That's above my pay scale, I'm afraid. You need to talk to SY 😉
jd
It's OK, guys. I don't expect any of this crowd to believe me, or anything useful that I might say. Netlist asked, and I gave. That is all there is to it.
It appears to just be the distortion on the power line, you know, like your wall outlet. Who needs a load for that?
Yes but would the distortion be there without any load current? As I noted, it's just the same wave-form you see on the neutral with a cap input power supply. With some noise, which is subsequently removed.
Now I do agree that that is an improvement. There are many ways to get such an improvement. What was the price of the devices to get this difference?
jd
Of course, look at your own power line, just passively notch the 50 Hz (in your case) 60 Hz for us. Haven't you even tried?
I prefer Cedric. I suspect Jan does as well.
Interesting, the waveform of the line voltage (if that's what it is) looks like it's clipped on the bottom.
What I want to know is...
If you've got a gizmo that turns this:
Into this:
Why on earth would anyone want to put such a thing in the audio signal path?
se
Into this:
se
Why would a .02 ohm resistor be helical?
Because that's how they trim metal film resistors to the to the final value.
se
Sometimes it improves things, sometimes not. However the mechanism that makes it happen is not obvious to doubters, like yourself, because there is not significant inductance, capacitance and only modest resistance, by any measurement normally used in a laboratory. It does sometimes look like a 'noise gate' and I too wonder if that is such a good thing. However, Jack has a different explanation, but you would not begin to believe it, so I will let it alone.
Think this helical thing through everyone. How much resistance multiplication you get from cutting a helical path? Is this a good way to TRIM a resistor, if it is in the ball-park in the first place? .02 ohms isn't much.
Worked with and still do with Dranetz-BMI equipment. If I recall the bandwidth of that old dog was sufficient to capture the transients we are seeing accurately, so I think the graphs can be trusted, albeit with limited test setup information.
The magnitude difference between with-Bybee and without-Bybee are significant. We aren't talking microvolts, here - this is something easily seen on any 10 MHz scope. I am a little miffed as to all the debate about "measurements aren't everything". Why the need to claim the Bybees do something we aren't able to measure, but they work nonetheless?
If the test setup was proper and the QP really did in fact filter out the hash as shown, this is easily quantified, reproducible, and measureable; and with much better test equipment than an old BMI. A few simple measurements with a spectrum analyzer would be all that is necessary to permanently silence us pig-headed engineers that insist on some objectivity before believing in the Bybee. If those documented measurements can be performed, Jack would find his sales skyrocketing, as subjectivists and objectivists would both be lining up to install these magical devices in their equipment.
Either that, or it would be found that the QP is really just some kind of LP filter. Maybe that would hurt sales if we determine we can get the same performance out of an RF choke.
Every explanation Jack has offered, either on his website or from his own lips has been shown to be a load of nonsense.
se
Bybees are simply too expensive to be practical with economically concerned individuals. I couldn't afford them, and many here would rather spend their extra cash on good wine and food, etc. That's OK with me.
Actually Jack is understanding of the limited measured effect these devices evoke, and is working on releasing practical circuitry, in module form, that cleans up the AC line many times better. However it is still relatively expensive for most applications, even my own.
Audio Phenomena
113/22-23 Prachautit Road
Radburana, Bangkok, THAILAND
Tel: (66) 083-0948454
E-mail 1: hiroyuki5555@hotmail.com
E-mail 2: info@audio-phenomena.com
Web: Audio Phenomena : Thailand's Home of Bybee Technologies, Elrod Power Systems, Acoustic Revive!
Audio Phenomena is the exclusive distributor in Thailand for Bybee Technologies products. We are pleased to offer consultation regarding system upgrades using the latest unique Bybee technologiess. Whether your upgrade needs are for internal equipment modification or exterior modification at the main AC line, we can advise you on how to get the best result from your modification. We also stock most of the latest DIY parts and plug-in accessories from Bybee, including the revolutionary Golden Goddess 'Super Effect" Speaker, RCA and XLR Bullets.
Audio Phenomena
Audio Phenomena is the exclusive distributor in Thailand for Bybee Technologies products. [/B]
One can only hope that these don't fall into the wrong hands!
As much as you want depending on how much you cut out.
Who says it's in the ballpark in the first place?
And yes, it is a good way to trim a resistor. What, you think they coat the cores separately for each and every standard value and manage to do it to within 1% or less of the final value?
What they do is coat within much broader ranges and then laser trim them to their final value.
se
- General Interest
- Everything Else
- Bybee Quantum Purifier Experience.
