Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th September 2008, 07:52 PM   #11
scott wurcer's Avatar
Originally posted by jcx
loudspeakers could be acoustic filtered as mentioned above, indirect measurement of microphone IMD products in the sound feilds of 2 speakers driven with different frequencies could avoid the harmonics in each speaker's output
Shocked again, I was working out the best way to do this just last night. I was going to try to exercise the diaphram with a large lowish frequency tone (B&K mentions 90Hz in their handbook) and then using a lower level one at a higher frequency look for the IMD tones on the high frequency one with FFT's. I figure with enough averaging one could resolve pretty far down in the noise. Just a couple of power levels about 20dB apart should get some kind fit to theory for say a transducer with small 2nd and 3rd order non-linearity. Sort of indirectly trace the transfer function.
Has this ever been written up anywhere? Going up to 140dB on
the 90Hz might require the rest of the households cooperation.
Pain is never permanent
Old 17th September 2008, 04:10 PM   #12
jcx is offline jcx  United States
a question occurs to me:
How does Doppler effect enter in this setup? - any high frequency sound reflected from the low frequency driver will be modulated - can the Doppler products be separated by phase? or do you just have to make them small (driver directivity?) and accept the residual as a resolution limit?
Old 17th September 2008, 04:43 PM   #13
Iain McNeill's Avatar
If I understand you correctly, you're using the intermodulation components to test the microphone distortion. The doppler components will be sidebands of the HF signal. Can't you just arrange the IM components to be away from the HF sidebands?
...or am missing something?
Old 17th September 2008, 05:39 PM   #14
I was thinking maybe a shaped burst of 90Hz might help, but I think separation and directivity would be enough. Also prefiltering out the low tone would make the post processing easier, at least dynamic range wise.
SMPS to Pure Sine EUVL Power Supplies 2 11th June 2009 05:24 PM
FS:Pure Sine Inverter 300w rubydac Swap Meet 0 25th April 2008 05:39 AM
sine waves on nos dac regal Digital Source 5 11th March 2007 10:38 PM
Sine and square waves percieved pitch, why? baggystevo82 Everything Else 33 11th March 2005 05:18 AM
Pure sine wave? PeteMcK Multi-Way 12 4th July 2004 07:31 AM
Page generated in 0.07962 seconds (72.05% PHP - 27.95% MySQL) with 10 queries
