diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   modified ATX (current mode) (http://www.diyaudio.com/forums/everything-else/129566-modified-atx-current-mode.html)
xyz9915 11th September 2008 02:48 AM
2 Attachment(s)
Hi!
The attached file is a modified schematic of ATX power supply which I want to use as current mode supply. So the output current from current sense transformer was used at Pin4 (Deadtime Control) of IC TL494, through variable resistor to adjust the desired current (9A). Please comment if this technique can deliver a constant current output. Voltage regulation is not necessary.
sivan_and 11th September 2008 07:25 AM
current has to be sensed from the switching transformer (t3)
Resources saved on this page: MySQL 18.75%
