| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
can i run a 50 hz motor at 60 hz alternating voltage, if not please tell me what modifications should make about the motor to run it.
M D |
#2 |
I think you can use 60Hz motor at 50Hz with 10% derateing, but not the other way around.
#3 |
well you can but syncronous motors use the mains frequency to control their speed. the motor will run fast.
There are a couple of things you could do, Build a 50hz power supply or alter the motor pully output size to match the new speed. What is the use, record player motors often had alternative pulleys or idler wheels to cope with frequency differances in different parts of the world for example with out changing the motor. |
#4 |
What is the application and is it speed sensitive?
Motors designed to run at 50Hz but operating at 60Hz will generally run cooler but about 20% fast which will matter if the motor is used in a speed sensitive application such as in a turntable or capstan motor in a tape deck. (Fans, supply and take up reel motors don't care, but need the right value of phase shift cap installed if present.) Motors wound for 60Hz and running on 50Hz often have issues with overheating and need to be derated due to additional losses imposed due to insufficient winding inductance. Motors using phase shift capacitors (larger synchronous motors) will need different value capacitors in order to maintain the proper phase shift for quiet operation and good torque output. 50Hz motors with proper value phase shift caps do not need to be derated when run on 60Hz providing that they are running within the allowable design voltage range.
www.kta-hifi.net |
#5 |
thanks guys for these precious replies
M D |
| Help required for using a FDD motor as a turntable motor. | binspaul | Analogue Source | 5 | 13th May 2009 03:59 AM |
| Lambda motor vs. XBL^2 motor vs. any other motor | Thinkcat | Subwoofers | 16 | 23rd December 2008 06:23 AM |
| DIY TT: motor, motor PS, platter speed measurements | dice45 | Analogue Source | 52 | 9th May 2006 01:07 PM |
| DIY TT motor | FrancoB | Swap Meet | 3 | 18th May 2005 08:43 AM |
| dc motor | dionysio | Analogue Source | 1 | 3rd May 2004 01:09 PM |
| Page generated in 0.08764 seconds (77.79% PHP - 22.21% MySQL) with 10 queries |
