| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
This is one of those tools that should be in every DIYer's tool box.
Would appreciate recommendations on a half way decent one with a reasonably consitent accuracy. Best seraph |
#2 |
Bosch electric 11Volt screwdriver. Very nice to use, and surprisingly quiet.
As far as a manually set screw driver with adjustable torque settings, do a search on Google or similar. Not sure if you can get a adjustable torque setting ratcheting screw driver
stew ☮ -"A sane man in an insane world appears insane." |
#3 |
#4 |
Nordic, wow! not cheap equals?
Is RS Radio Shack? our Radio Shacks in Canada sell bar accessories and that's about it. stew
#5 |
Since you are in the US what about Snap on?
http://buy1.snapon.com/catalog/tools...e=snapon-store I've used their torque wrenches for years in my past life as a car mechanic and never faulted them, other than they are very expensive in the UK. Then again so is everything. The only time we used anything with a range that small was to adjust the brake band tension in auto gearboxes (the work of the devil). John |
#6 |
#7 | |
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#9 |
My favourite power screwdriver with a torque clutch came from Walmart for under $20. I use it for screwing PC boards down to standoffs with 4-40 screws, or running nuts onto ground studs. I don't know how accurate the torque settings are, but they seem good enough. For the price it's incredible, and more suitable to this use than any other power screwdriver I've used. They're either too low RPM or too heavy to be comfortable.
If I'm putting wood screws into a speaker cabinet, then I'll prefer a real driver/drill like a 9.6V Makita kluged to run off a 12V car battery. |
#10 |
Some great recommendations. Thanks very much everyone.
| help me i was hookin up the rmt and the screwdriver stuck to the body an it just quit | razordave123 | Car Audio | 8 | 19th July 2009 04:00 PM |
| Torque Bass Amp T100 1EB Need Transistor | Trev666 | Vendor's Bazaar | 0 | 8th August 2007 10:58 AM |
| Insulated screwdriver for RF coil tuning | jackinnj | Everything Else | 0 | 4th November 2005 03:14 PM |
| what do you recommend | pd0019 | Multi-Way | 0 | 23rd February 2005 06:40 AM |
| How many µF do you recommend for this amp? | hugobross | Solid State | 3 | 29th September 2001 12:39 PM |
| Page generated in 0.08877 seconds (87.52% PHP - 12.48% MySQL) with 11 queries |
