| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
This is probably a long shot, but I need some advice on how to trace (find) coaxial cables installed in a wall.
I know where one end is, but not the other. Thanks! |
#2 |
Where I live, the local 'home depot' sells small battery-powered thingies that locate any cabling or piping, as long as it is metallic, in a wall. I don't know how they are called at your end, probably something like 'cable finder'...
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
Maybe this could work: http://www.homedepot.com/webapp/wcs/...ctId=100395149
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
That will find AC lines only (due to large radiating magnetic field). It will not find a coax cable with a small video signal or no signal at all.
If you know where one end of the cable is, and you want to find the other end, you can short the end that you do have (connect the centre conductor to the shield). Take your multimeter and check all the coax cables you can find, hopefully one of them will be shorted.
The power of Science compels you! |
#5 |
If you have access to one end and the other is more or less floating, you can use the kind of cable tracer used by telephone workers: it is a small device connected between the shorted pair (the coax braid in your case) and the ground (earth, distribution frame, pipe, etc.... ). It sends a powerful and characteristic audio signal which is picked up capacitively by a high impedance receiver. It can detect a cable at up to some tens of centimeters, if there isn't too much obstruction. LV |
#6 | |
What I was initially thinking of was a device I used many years ago, where you would place a battery operated probe across the power leads in a junction box, and then walk around with a sniffer and follow the cable. It would work through metal conduits - pretty cool. I was stymied with coax, since it's shielded, but I like your approach. It worked by overlaying a high frequency signal (about 1-2 kHz) over the power line fundamental. However, in the end, I had some notion of where I buried that cable in the wall, and just removed a 6 foot slice of drywall and found it. More work, but no fancy test gear to go buy. Thanks for the creative suggestions! |
| coaxial | adason | Multi-Way | 28 | 2nd June 2007 01:18 AM |
| ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! | ssabripo | Everything Else | 3 | 26th October 2006 02:33 PM |
| Matching and curve tracing | janneman | Solid State | 1 | 27th August 2004 03:57 AM |
| cables for diy amps, preamps, and speaker cables ... | paulspencer | Solid State | 5 | 3rd August 2004 07:14 AM |
| signal tracing or other circuit checkout methods | Zapped | Pass Labs | 7 | 12th September 2002 06:53 PM |
| Page generated in 0.08589 seconds (81.03% PHP - 18.97% MySQL) with 10 queries |
