| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I am trying to retrofit my Dual 510 with an LED strobe, as the neon it came with starts only intermittently and sometimes goes out. I have built the attached simple circuit on the neon strobe PCB, it works fine in steady state, but kills LEDs at startup. I'm sure some may consider it a safety risk as well, but either way - an I or V surge is killing the LEDs at start. D1 is actually two LEDs in series, not that it matters.
I am wondering if someone has a simple (must fit in a very small space) alternative or can tell me what is wrong with my circuit that is frying LEDs. It'd be a bonus to get 120Hz instead of 60Hz. Thanks
http://audio.gotroot.ca/ |
#2 |
If the LED keeps diying you can try reducing the cap by half. And fit a high power zener across the LED. For frequency doubling you can try feeding the LED from the output of a bridge.
#3 |
Did it Himself
They are dying due to the cap being a short at first turn on, an if that is on a part of the waveform that is much more then zero the current surge is too much. The solution is to add some resistance.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Turntable Strobe Lights | dhaen | Vendor's Bazaar | 0 | 29th December 2007 08:37 AM |
| Strobe Lights and Bass | CARTRulz | Subwoofers | 10 | 10th September 2006 12:36 PM |
| Pre amp? What schematic do i need? | silentblackhat | Solid State | 21 | 16th March 2006 06:47 AM |
| Turntable strobe | dhaen | Swap Meet | 4 | 6th March 2004 08:53 AM |
| Page generated in 0.06902 seconds (64.30% PHP - 35.70% MySQL) with 11 queries |
