| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
hello guys.
i wanted to tweek my bike ,so i got a set of gauges from the newest model. i didnt check before buying , so apparently this new gauge is getting all the important signals (speed , temp etc) on a single wire - serial data from the main engine control unit. inside there is nec 8bit microcontroller 78063 (a) series . just wanted to know , if its 8 bit microcontroller , does it mean that it recieves data 8 bit at a time? and , if the input is only one wire (except grount) , how can the input data be synchronized with the microcontroller pulse this way? heres the datasheet for the mcu http://www.eu.necel.com/_pdf/U10335EJ2V0DS00.PDF any help would be great
if you are not living on the edge you are taking too much space |
#2 |
No. An 8 bit microcontroller has a nominal register width of 8 bits. That does not mean that the signal being received is in 8 bit chunks. The signaling protocol between the engine computer and your gauge could be set up in a zillion different ways. The data is probably packaged in some combination of address, synchronization, and error correction.
I_F |
#3 |
thanks allot!
oh ,well , i guess i will need to make my own counters and connect them to the 7 seg lcd displays and tachometer
| Microcontroller Help | imix500 | Parts | 8 | 3rd September 2008 02:49 AM |
| FLAC on microcontroller | gene_klein | Digital Source | 4 | 1st December 2007 02:44 PM |
| microcontroller programming | traf | Digital Source | 7 | 12th September 2007 12:49 PM |
| No microcontroller for PGA2310? | louischia | Chip Amps | 12 | 4th March 2007 06:12 PM |
| Aleph P - microcontroller | Klaus | Pass Labs | 23 | 7th November 2005 06:27 PM |
| Page generated in 0.07420 seconds (78.03% PHP - 21.97% MySQL) with 10 queries |
