| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#401 | ||||
I would like to hear you break down the events that take place as sound travels through water as per your theory much like I did in the post you were replying too. I want to know how displacement, heat, and expansion of volume all take place. I want to know their causes and the order they occur in. I want to hear "Aqueous Sound Transmissions According to John"! Quote:
byproduct: a secondary result, unintended but inevitably produced in doing or producing something else. ...it sounds to me that a byproduct IS a direct result. See this is how it works, the desired result is the transmission of sound through water, the byproduct is a minuscule increase in temperature which results in a microscopic increase in volume. However an increase in volume is not displacement! If you have a pot of water filled to the brim and you place an object in it, it will overflow. If you take that same pot of water and set it to boil it will overflow. Each time the result was the same, however the means by which the end result was achieved was very very different! Quote:
The main problem is that you keep jumping around instead of remaining on one point, and proving that point! I was on your side at the beginning of this thread, and was open minded enough to forget my views and opinions, but you just talked in circles and proved nothing. I know how sound travels through water John, but do you? Quote:
-Justin |
#402 | ||
What are you getting at? At 4*C, water is at it's maximum density at standard pressure. Use sound energy to excite the molecules and they will expand the volume. Temperature change, density change, volume change. Quote:
??? Are you losing it?
#403 |
First principles again:
Archimedes gets into his bathtub. A certain amount of water, equivalent to the volume of his body, is moved (dis-placed) from its original position in the tub onto the floor, since both Archimedes and the water cannot take up that space at the same time. So far, so good. In a second experiment, Archimedes lights a fire under the tub. The water expands, and some of it overflows onto the floor. It has not been displaced (in the scientific sense of the word), since the tub remains entirely full of water. However, I suspect that you, John, would use the word 'displaced' to describe what happens to the water in the second case. Here is an example of the need to apply strict definition of terms to avoid confusion and misunderstanding. (A further point - as a good physicist, Archimedes will, no doubt, ensure that the temperature in the first experiment remains constant, so that he can be sure that all the water on the floor is a result of displacement, and not of expansion.) ***** Not directly related to the above - a thought experiment (or a practical one, if you want to...): Set up an acoustic transmitter and receiver either end of a vessel filled with water. Observe the transmission of sound from transmitter to receiver, by (according to you) a mechanism whereby the energy input heats the water locally , which expands, and is thus 'displaced' - is this a fair summary? Now place a cooling coil in the vessel, and use it to extract exacly as much heat as is being added to the system by the transmitter. What is observed at the receiver? Why? |
#404 |
...truth seeker...
John,
I think many of us see that water expands with decreasing temperature just above freezing. I think many of us see that the converse of this...water density increases along with temperature in this small range...is also true. I think many (probably all) of us see that you are unable to resolve another apparent conflict with your compression/temperature/density morphism of the moment. I think you have been the recipient of a great deal of well intended effort put forth by eminently talented people. I think your lack of acceptance has...by your own actions...placed you in a position where you can expect less sincere help in the future, maybe when you need it more. I hope you get what you need. I don't think you will find it here.
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#405 | ||
My use of "displacement" has be used in a specific context, and I thought that there would be no confusion. As usual, I was wrong. Quote:
The cooling coil is performing a separate task and will have no effect on the transmission of sound. The same thing is happening - displacement and volume increase from the sound energy. All that the cooling coil is doing is drawing the same amount of energy out of the water. This does not interfere with the first process. The end result is no volume expansion and no temperature change. Sound was still transmitted though. |
#406 | ||
#407 | |
You sure about the above? Doesn't water expand below freezing? We know it expands above freezing, everything expands with increased temperature. Wouldn't the density decrease as the volume expands? |
#408 | |
At 4C there is no change in density with temperature in fact at 3.5 C the density goes the other way. Average back and forth around 4 C and there is no net change in density no volume change. Asymptote, slope of zero remember? OK look at it another way. There is a dramatic difference in the rate of change in density with temperature around 4 C, in fact it changes sign. There are no corresponding changes in the propagation properties of sound. Heat flow obeys diffusion laws. The time constant determined by the thermal capacity and thermal resistance are orders of magnitude less than the speed of sound propagation (in general). The solutions to diffusion equations also do not support traveling waves.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#409 |
This looks to be a variation on the "Topper Syndrome",
as in "That's nothing, lemme tell you about MY STORY..." http://7akifadi.com/2007/06/26/the-topper-syndrome/ mangled into the format of "whatever you say or demonstrate to the contrary or to refute what I say, I'll re-define whatever you thought I was saying to something with a new set of rules, thus proving whatever you said or demonstrated is/was irrelevent to whatever it is that you thought I meant> Justin... Not even if I supply a titanium shark cage??? John L.
"...His brain is squirming like a toad..." Jim Morrison |
#410 | |
Mobile Sound Science |
