| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 | |
If this isn't what you picture when you think of a wave something is wrong:
#12 | |
They are imaging pressure changes. |
#13 | |
#14 | |
If there's a sucker born every minute, where do the rest of them come from? |
#15 | |
http://www.engineeringtoolbox.com/so...ids-d_713.html note speed of sound in aluminium is 4.9km/s while in steel is 6.1 km/s. In diamond (stiffest!) is 12km/s !!! Water lags at 1.4km/s ... |
#16 |
I have no idea where this is getting hung up. Are you just unhappy with the use of the words "compression and rarefaction" instead of "areas of low and high pressure"? These are equivalent to me.
You've already agreed the molecules move over toward their neighbors to transmit the vibration = what everyody has been trying to say. Argument over as far as I'm concerned. |
#17 |
Bratislav, maybe I wasn't clear or I'm not reading you right but I think we're agreeing.
It's my understanding that: Stiffer = faster denser = slower and it's the balance of these two effects that determines the speed. The density of water would make the speed of sound slower than air if it weren't for the greatly increased stiffness that more than makes up for that. |
#18 | ||
Hear the real thing! |
#19 | |
You seem to be saying that your mind is made up, and you will accept neither long accepted physical principles, nor actual measurement of the phenomenon as evidence. If so, it's a matter of faith and is not subject to the scientific method, and there is no point in discussion based on that method. If that's not the case, what evidence do you require? Sheldon |
#20 |
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
MJL21193
“Compressibility has absolutely nothing to do with sound. Zero.” “Density has everything to do with sound transmission.” “Is there not one reader of this thread that understands this? I encourage him or her to jump in.” Woa dude you have such a confident grip on this, Who would continue to try to explain to you? Perhaps you can deduce the answer on your own. Here is a thought experiment for you, pretend you are in space, zero G, at 1atm air pressure. You take microscopic lead powder and evenly disperse it in the air so that say a fourth of the total volume is powdered lead. Now, you have raised the density of the atmosphere / gas significantly above water with lead powder and you measure the properties of sound traveling through this medium. Is the sound velocity higher like you say because of greater density, or lower becasue the mass driven by each spring is greater but the spring constant unchanged.? Can you picture where the spring force comes into play? Can you picture that any spring regardless of how “incompressible” it appears to you personally, is compressible, only the ratio of force to motion changes (like V and I or in impedance) and this is a continuum. Can you picture the mechanism that transfers force from one air or water molecule's mass to another, IS a spring? Can you picture this connection of springs driving masses forms the equivalent of an L&C electrical delay line and produces a finite speed of sound? Can you imagine that all compressional sound waves travel by this mechanism, even in water or metal or Diamond? Best, Tom A great line too. click click 5,4, "Oh No…"3, 2,1 - Jean-Baptiste Emanuel Zorg
Bring back mst3k and futurama |
| Page generated in 0.71169 seconds (100.00% PHP - 0% MySQL) with 10 queries |
