| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#91 | ||
...truth seeker...
You are explaining yourself clearly...your conclusions are incorrect. Quote:
Where is there any supportive argument in the literature for what you are concluding ? edit: clarify
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#92 | |
Temperature and pressure both change when you release the steam. look at a can of compressed air--you know, those "electronics dusters". Or even a propane tank. both have highly compressed gases to the point where they are liquid (no temp changes, they are stored at room temp) if you quickly release the gas, what happens? pressure inside the can drops fast and the can is rigid so volume can't change to accomodate the pressure change. net result: the can gets COLD. pressure drops inside the can and temperature drops to catch up with the pressure drop. then after a short while, temperature re-equalizes with the room temperature and the can's internal pressure rises again. you could do this with water if it was a gas at room temperature too. |
#93 | ||
#94 |
Under the circumstances, I think you're been treated pretty well, John. To your credit, you've shown you're willing to back up and ask questions. Maybe there's hope for you yet.
In my opinion, you're making this too complicated. It should be good enough to use the balls-and-springs analogy here. What you are saying is that for water, in its (not it's) liquid state, the springs between the balls are infinitely stiff. It follows that if you line up a series of balls and springs and push on the ball at one end, then the ball at the other end will start moving instantaneously. If this is true, then this represents transmission of information at infinite speed, something we ought to agree is impossible. The thought experiment of the line of molecules extending from Earth to Proxima Centauri is just an extreme way to illustrate the point. If, on the other hand, we concede that it takes some time for the displacement wave to travel from one end of the sample to the other, then it must be that in the interim the sample has been compressed -- one end moved, but the other didn't. Since most of the space inside a volume of water is vacuum, you might want to ask yourself what the mechanism is that transmits the force from one molecule to another. Then research the properties of that force and understand why it acts more like a spring than like a perfectly rigid rod. -Henry |
#95 | |
The medium is at 4*C, standard pressure - this is the condition before sound. When sound starts to move through it, it changes density and temperature. It only stands to reason that the excitation of molecules from the energy of the sound wave will increase temperature from friction. With this temperature change, you will see a density change, as density will decrease as temperature rises. Energy from the sound wave is being dissipated in the medium - this produces heat. For the above, the medium could be at any constant temperature or pressure. Injecting energy from a wave source produces movement which in turn produces heat from friction. Heat will increase temperature, density will lower. How is this conclusion incorrect? |
#96 | |||
#97 | ||
![]() Quote:
#98 |
Sorry if I missed this already posted, but this is my favorite resource on wave propagation in solids vs liquids vs gasses. Unfortunately a couple of the equations have broken links now but almost everything is there.
http://hyperphysics.phy-astr.gsu.edu.../sprop.html#c1
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#99 | ||||
...truth seeker...
from post 95:
The passage of a sound wave is not one sided. The density fluctuates from the high side to the low side of "standard pressure" in cycles. Be careful, you have almost admitted to the compression of water by using those statements. Quote:
#100 | ||||
BTW, I know the difference between its and it's, but thanks for the corrective email and the lesson anyway. Quote:
I'm glad that you feel there is hope for me, and I am impressed that you have "compressed" your posting frequency down from 1 in a hundred days to voice your thoughts here. Quote:
